You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide will show you how to replace the front-facing camera on this device. As with the back-facing camera, this replacement will require most of the phone to be taken apart beforehand.
  1. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top. Remove the back casing of the phone using the notch located at the top.
    • Remove the back casing of the phone using the notch located at the top.
  2. Lift up the battery using a plastic spudger or fingernail. Damaging the battery may result in physical injury and/or damage to the phone. Damaging the battery may result in physical injury and/or damage to the phone.
    • Lift up the battery using a plastic spudger or fingernail.
    • Damaging the battery may result in physical injury and/or damage to the phone.
  3. Turn on the heat gun. Make sure you don’t touch the metallic tip. You will burn yourself.
    • Turn on the heat gun.
    • Make sure you don’t touch the metallic tip. You will burn yourself.
    • Hold the heat gun roughly 6 inches away from the screen of the phone and slowly run the heat around the edge of the screen.
    • Keep at least 6 inches of distance from the screen. Keep moving the heat around to avoid warping the phone screen or internal parts.
  4. Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible. Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
    • Using a plastic opening tool or spudger, pry up the screen after the adhesive has melted.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Because it is a water-resistant phone, the screen cannot be taken apart without breaking.
  5. The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger. In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • The plastic cover of the phone may separate from the LCD screen. If so, also remove the LCD screen with the regular nylon spudger.
    • In the upper right area of the LCD screen, there is a connecting ribbon. Be careful not to rip its connection to the motherboard.
    • Do not hold the phone too close to your face or eyes. Small glass shards may dislodge or the metal spudger may slip.
  6. Remove the screws around the plate Remove the screws around the plate Remove the screws around the plate
    • Remove the screws around the plate
  7. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity. Push the plate out by applying pressure to the battery cavity.
    • Push the plate out by applying pressure to the battery cavity.
  8. Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily. Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily. Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
    • Remove the camera from the plug at the top of the phone with tweezers. It should pop out fairly easily.
Caroline Janiszewski
516 Reputation
4 Guides authored
USF Tampa, Team 1-6, Leahy Spring 2016 Member of USF Tampa, Team 1-6, Leahy Spring 2016
USFT-LEAHY-S16S1G6
3 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 493
