Samsung Galaxy S5 Motherboard Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Galaxy S5 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 2 Samsung Galaxy S5 Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 2
    • Carefully wedge the tip of a spudger underneath the antenna cable connector.
    • Delicately lift the spudger directly upwards to disconnect the antenna connector off its socket on the motherboard.
  2. Samsung Galaxy S5 Motherboard Assembly Replacement: step 2, image 1 of 2 Samsung Galaxy S5 Motherboard Assembly Replacement: step 2, image 2 of 2
    • Pull, but do not remove, the camera end of the motherboard up from the midframe to allow access to the connectors on the rear.
    • Do not attempt to fully remove the motherboard as it is still attached to the interior midframe by the Micro-USB port daughterboard connector.
  3. Samsung Galaxy S5 Motherboard Assembly Replacement: step 3, image 1 of 2 Samsung Galaxy S5 Motherboard Assembly Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to pry the daughterboard connector straight up off its socket on the motherboard.
  4. Samsung Galaxy S5 Motherboard Assembly Replacement: step 4, image 1 of 1
    • Remove the single 3.0 mm Phillips #000 screw securing the motherboard to the midframe.
Sam Goldheart
466,244 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,433 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 373
