Introduction
If the device exhibits trouble playing sounds during calls, notifications, or the use of applications, it might be a good idea to replace the loud speaker on the rear of the phone.
Remove the back cover of the cell phone using a plastic opening tool.
The LEGO Brick Separator (https://www.lego.com/en-us/service/brick...) also works perfectly if you don’t have the iFixit Opening Tool handy.
Remove Sim Card using a tweezer or fingers
Remove Memory Card using a tweezer or fingers
In the back, there are 10 screws with a , which have to be removed with a small Phillips screwdriver tool.
Then, use the plastic opening tool around the cellphone to open the plastic gray cover
Exert the gray cover from the plate and screen would come out easily.
Exert some pressure on the gray cover to separate the loud speaker from the plate.
31 other people completed this guide.
3 Comments
my phone has sound!!!!!! thank you for the tech advice
loud & clear Thanks
perfect. thankyou
