Samsung Galaxy S4 Headphone Jack Assembly Replacement
  1. Samsung Galaxy S4 Headphone Jack Assembly Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S4 Headphone Jack Assembly Replacement, Rear Case: step 1, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 2, image 1 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 2, image 2 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 2, image 3 of 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Samsung Galaxy S4 Headphone Jack Assembly Replacement, Battery: step 3, image 1 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement, Battery: step 3, image 2 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement, Battery: step 3, image 3 of 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  4. Samsung Galaxy S4 Headphone Jack Assembly Replacement, SIM Card: step 4, image 1 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement, SIM Card: step 4, image 2 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement, SIM Card: step 4, image 3 of 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
  5. Samsung Galaxy S4 Headphone Jack Assembly Replacement, Midframe: step 5, image 1 of 1
    • Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  6. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 6, image 1 of 2 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 6, image 2 of 2
    • The midframe is secured to the display assembly by several plastic clips behind the chrome bezel of the midframe. The next few steps will guide you through separating the clips to free the midframe.
    • Starting on the volume button side of the phone, insert your plastic opening tool between the chrome bezel around the display glass and the larger chrome border piece. Look for the seam between the two.
    • Slide the opening tool along the seam, separating the plastic clips as you go.
    • Be very gentle whilst prying, and pry only enough to separate the plastic clips—there are several thin points in the midframe bezel that may crack if you bend them too much.
  7. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 7, image 1 of 2 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 7, image 2 of 2
    • Continue prying around the corner of the phone.
    • Slide your opening tool along the seam between the midframe and display along the bottom of the device, releasing more of the plastic clips.
  8. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 8, image 1 of 2 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 8, image 2 of 2
    • Again, pry around the corner, to the power button side.
    • Slide the opening tool along the seam.
  9. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 9, image 1 of 2 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 9, image 2 of 2
    • Continue sliding the opening tool around the top of the phone, releasing the last of the clips and freeing the midframe from the display assembly.
    • At this point, you may want to run your plastic opening tool along the entire perimeter of the device again, to make sure you've released all of the plastic clips.
  10. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 10, image 1 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 10, image 2 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 10, image 3 of 3
    • Remove the midframe from the display assembly.
  11. Samsung Galaxy S4 Headphone Jack Assembly Replacement, Motherboard Assembly: step 11, image 1 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement, Motherboard Assembly: step 11, image 2 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement, Motherboard Assembly: step 11, image 3 of 3
    • Use the flat end of a spudger to disconnect the USB board connector.
    • Disconnect the front-facing camera cable connector.
    • Disconnect the earpiece speaker assembly cable connector.
  12. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 12, image 1 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 12, image 2 of 3 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 12, image 3 of 3
    • Disconnect the headphone jack assembly cable connector.
    • Disconnect the display/digitizer cable connector.
    • Disconnect the antenna cable connector.
  13. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 13, image 1 of 1
    • Remove the single 2.4 mm Phillips #00 screw from the motherboard assembly.
  14. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 14, image 1 of 2 Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 14, image 2 of 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  15. Samsung Galaxy S4 Headphone Jack Assembly Replacement, Headphone Jack: step 15, image 1 of 1
    • Remove the single 2.4 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
  16. Samsung Galaxy S4 Headphone Jack Assembly Replacement: step 16, image 1 of 1
    • Remove the headphone jack assembly.
37 other people completed this guide.
Sam Goldheart
465,822 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,137 Guides authored
8 Comments
I accidentally inserted an electric pin instead of the auxiliary jack into the head phone jack assembly. There was a loud screeching sound and ever since then the head phones do not work. However, I can play music through the phone speaker and also with Bluetooth. I cannot listen to music with my ear buds or head phones or with auxiliary speakers. I have replaced the jack assembly with a new one and yet it is the same. What more can I do to rectify this?
Guy Paranavitana - Reply
Did you ever get help on this? Having the same problem.
Jace Blackburn -
Me too have same problem....did u got it fixed or not?...if yes how u did it...?
reone -
I too am having this issue. I assume we have fried the amp for external audio with wtv current we happened to let touch our aux ports. Sounds like I bigger issue to fix. Just still wondering if I can.
Zadboy Tanaka -
Where do you even get the part?
Albert Einstein -
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 31
All Time: 46,466
