Samsung Galaxy S4 Gorilla glass replacement Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
  1. Samsung Galaxy S4 Gorilla glass replacement Replacement, if you lcd still works like this example you can continue: step 1, image 1 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, if you lcd still works like this example you can continue: step 1, image 2 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, if you lcd still works like this example you can continue: step 1, image 3 of 3
    • If your LCD and everything else works fine and your phone look like this picture, you can change the glass
  2. Samsung Galaxy S4 Gorilla glass replacement Replacement, get a heatgun with knob: step 2, image 1 of 1
    • not all the heatgun are the same, get on with variable temperature
  3. Samsung Galaxy S4 Gorilla glass replacement Replacement, get a infrared thermometer like this one: step 3, image 1 of 1
    • in ebay you can get one for 10$
  4. Samsung Galaxy S4 Gorilla glass replacement Replacement, uv glue to glue the lcd with the gorilla glass: step 4, image 1 of 1
    • not all the glues are the same. Get XFACTOR or Octopus brand are good.
    • if you get something like you see in the picture make sure the caps are green and not blue, Those chinese brands sometimes can be crappy, the red tube with blue caps is the crappiest
  5. Samsung Galaxy S4 Gorilla glass replacement Replacement, replacement gorilla glass: step 5, image 1 of 1
    • most of the replacement on ebay are fine, make sure it has the brand on it. There are some they are blank.
  6. Samsung Galaxy S4 Gorilla glass replacement Replacement: step 6, image 1 of 1
    • get a great game cards in order to be able to separate the LCD from the broken glass.
    • dont be cheap ;-) buy the best quality you can get
  7. Samsung Galaxy S4 Gorilla glass replacement Replacement, victorinox cybertool has all tools you need to take it apart: step 7, image 1 of 1
    • it has nice blades to help you to separate the lcd from the broken glass. It has all the tips needed in order to remove all the screws and other parts
  8. Samsung Galaxy S4 Gorilla glass replacement Replacement: step 8, image 1 of 1
    • you can follow the video i made here.
    • just start moving the heatgun shooting heat all over the glass quickly and dont let it be over 100 degrees celsius or you will damage the LCD and it will turn gold, if that happen you will have to change the whole LCD module
  9. Samsung Galaxy S4 Gorilla glass replacement Replacement: step 9, image 1 of 1
    • a peak of 105 degrees is fine but keep it moving fast the gun so the heat will spread even in the whole LCD
  10. Samsung Galaxy S4 Gorilla glass replacement Replacement: step 10, image 1 of 1
  11. Samsung Galaxy S4 Gorilla glass replacement Replacement, inserting the card in the little gap you make with the blade: step 11, image 1 of 1
    • lift the glass with the blade and put the card
  12. Samsung Galaxy S4 Gorilla glass replacement Replacement, keep temp at 100 and insert card: step 12, image 1 of 1
    • do it slowing and keep applying heat
  13. Samsung Galaxy S4 Gorilla glass replacement Replacement, be careful with the flex: step 13, image 1 of 2 Samsung Galaxy S4 Gorilla glass replacement Replacement, be careful with the flex: step 13, image 2 of 2
    • keep heat and lift it up very slowly
    • flex is on the top be careful
  14. Samsung Galaxy S4 Gorilla glass replacement Replacement, clean the whole screen with alcohol: step 14, image 1 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, clean the whole screen with alcohol: step 14, image 2 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, clean the whole screen with alcohol: step 14, image 3 of 3
    • it has to be like a mirror. Here as the picture shows
    • use a cotton to clean and the plastic tool
  15. Samsung Galaxy S4 Gorilla glass replacement Replacement, removing back plastic and screws: step 15, image 1 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, removing back plastic and screws: step 15, image 2 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, removing back plastic and screws: step 15, image 3 of 3
    • remove all screws
    • remove bezel
    • remove front face camera
  16. Samsung Galaxy S4 Gorilla glass replacement Replacement, removing electronic and all related: step 16, image 1 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, removing electronic and all related: step 16, image 2 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, removing electronic and all related: step 16, image 3 of 3
    • remove screws from the logic board
    • unplug everything
    • leave lcd module alone
  17. Samsung Galaxy S4 Gorilla glass replacement Replacement, adding uv glue: step 17, image 1 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, adding uv glue: step 17, image 2 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, adding uv glue: step 17, image 3 of 3
    • do it slowly and dont make bubbles
    • when you put the new glass slowly too. use your knife to put it down
  18. Samsung Galaxy S4 Gorilla glass replacement Replacement, using uv light 365 nanometers wavelenght or the sun: step 18, image 1 of 2 Samsung Galaxy S4 Gorilla glass replacement Replacement, using uv light 365 nanometers wavelenght or the sun: step 18, image 2 of 2
    • i like this uv light instead of the sun
    • you can use sun as well but i dont recommend it
  19. Samsung Galaxy S4 Gorilla glass replacement Replacement, put all the pieces back: step 19, image 1 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, put all the pieces back: step 19, image 2 of 3 Samsung Galaxy S4 Gorilla glass replacement Replacement, put all the pieces back: step 19, image 3 of 3
    • put logic board + frontal face camera
    • bezel back
    • put all the screws.
    • turn it on
    • enjoy!!
9 other people completed this guide.
Gabriel barradenguy
590 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 9
All Time: 13,569
