Introduction
Use this guide to replace the headphone jack/speaker assembly.
Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
Gently twist the opening tool to disconnect the clips securing the top of the rear case.
Wedge a plastic opening tool into the small notch above the battery.
Pry the battery up out of its recess.
Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
After the click, release the card and it will pop out of its slot.
Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
98 other people completed this guide.
10 Comments
Thanks for the guide. It's the most detailed that I have seen so far. I'm looking for a headphone jack assembly replacement part that is compatible with a verizon s3 (i535), but they are difficult to find. Some of the sellers on ebay are advertising that their replacement for the i9300 is compatible with the i535, but I am not sure. Can you please tell me where you purchased your headphone jack assembly replacement?
Thanks!
Wendy
i had the same problem (no sound through the right ear)
i followed the repair guide, teared it apart and then, when i had the jack out of it i used a flashlight and a soldering iron
my guide:
use a very thin soldering iron, make it really hot, put very much solder on it
then stick it in the jack you have to be VERY FAST!!! otherwise the plastic will melt
now you have solder on the contacts and they touch the headphone plug again :)
worked fine for me, but only do this when you know how to solder!
it's a little risky but it's worth it
cheers
Markus
Thanks for the guide. We just replaced speaker assembly in my son's S3 with a $9 part off ebay, and it's working perfectly. Everything went like the pictures except there was slight difference between original and replacement. The hole next to the speaker in the replacement was a full circle, as in the last photo above, but the original was just a half-circle. We had to trim and file the replacement to match. Once we did that, it all snapped back together like new.
