Samsung Galaxy S III Battery Replacement
  1. Samsung Galaxy S III Battery Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy S III Battery Replacement, Rear Case: step 1, image 2 of 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Battery Replacement: step 2, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 2, image 2 of 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Battery Replacement: step 3, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 3, image 2 of 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Battery Replacement: step 4, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 4, image 2 of 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Battery Replacement: step 5, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 5, image 2 of 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Battery Replacement, Battery: step 6, image 1 of 2 Samsung Galaxy S III Battery Replacement, Battery: step 6, image 2 of 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Battery Replacement: step 7, image 1 of 2 Samsung Galaxy S III Battery Replacement: step 7, image 2 of 2
    • Remove the battery.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 78
All Time: 64,725
