Samsung Galaxy On5 Speaker Replacement
  1. Samsung Galaxy On5 Speaker Replacement, Battery: step 1, image 1 of 1
    • Locate the side notch that allows you to open the back casing.
  2. Samsung Galaxy On5 Speaker Replacement: step 2, image 1 of 3 Samsung Galaxy On5 Speaker Replacement: step 2, image 2 of 3 Samsung Galaxy On5 Speaker Replacement: step 2, image 3 of 3
    • Use a plastic prying tool or your fingernail to pop the back cover off of the phone.
  3. Samsung Galaxy On5 Speaker Replacement: step 3, image 1 of 3 Samsung Galaxy On5 Speaker Replacement: step 3, image 2 of 3 Samsung Galaxy On5 Speaker Replacement: step 3, image 3 of 3
    • Locate the battery notch and remove the battery, using either your finger or a plastic prying tool.
    • Be careful not to puncture the battery. Lithium-ion batteries are highly flammable when exposed to oxygen.
  4. Samsung Galaxy On5 Speaker Replacement, Speaker: step 4, image 1 of 2 Samsung Galaxy On5 Speaker Replacement, Speaker: step 4, image 2 of 2
    • Before dissembling the phone take out the SIM card and microSD card.
    • Use a plastic pry tool to slide both cards out.
    • Do not use a metal pry tool. Use of one can cause damage to the cards or the pins with the cards holder.
  5. Samsung Galaxy On5 Speaker Replacement: step 5, image 1 of 3 Samsung Galaxy On5 Speaker Replacement: step 5, image 2 of 3 Samsung Galaxy On5 Speaker Replacement: step 5, image 3 of 3
    • Take the plastic Spudger tool to pry open the LCD ribbon cable cover.
    • This part might be a little hard to open. Take your time and be careful not to push too hard, so there's no damage to the ribbon cable
    • Once the cover is remove, place the cover aside so its not miss placed
  6. Samsung Galaxy On5 Speaker Replacement: step 6, image 1 of 3 Samsung Galaxy On5 Speaker Replacement: step 6, image 2 of 3 Samsung Galaxy On5 Speaker Replacement: step 6, image 3 of 3
    • Take a plastic pry tool and work towards the top right of the LCD ribbon cable to pry the cable from the logic board.
    • Do not use a metal pry tool. Metal pry tools can cause damage to the logic board and to the ribbon cable.
    • This cable send signal from the logic board to the LCD screen.
    • Once unplugged move the cable aside.
  7. Samsung Galaxy On5 Speaker Replacement: step 7, image 1 of 2 Samsung Galaxy On5 Speaker Replacement: step 7, image 2 of 2
    • Take a PH00 Philip head and remove all 9 screws. Once done place them aside where you won't lose them.
    • All 9 screws are the same size.
  8. Samsung Galaxy On5 Speaker Replacement: step 8, image 1 of 2 Samsung Galaxy On5 Speaker Replacement: step 8, image 2 of 2
    • Use iFixit plastic picks to pry away the LCD from the bask assembly.
    • This process will take a bit due to the glue thats holding the LCD and back assembly together. Slowly move around the edge go the screen to loosen the glue up.
    • If you have a heat gun, you can use the heat gun heat up the glue. That will make the use of the plastic picks easy to pry the pieces apart.
  9. Samsung Galaxy On5 Speaker Replacement: step 9, image 1 of 3 Samsung Galaxy On5 Speaker Replacement: step 9, image 2 of 3 Samsung Galaxy On5 Speaker Replacement: step 9, image 3 of 3
    • Once both the LCD and back assemble come apart, look at the back assembly which the speaker is located.
    • Once located take a the plastic pry tool to remove the speaker of its housing. And replace it with a new one.
The Dark Night part 2
983 Reputation
5 Guides authored
Gateway, Team S1-G5, Luster Fall 2018 Member of Gateway, Team S1-G5, Luster Fall 2018
GCC-LUSTER-F18S1G5
1 Member
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 8
All Time: 959
