Up to 20% off select tools
Toshiba Portege R705-P35 Back Plate Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
61
All Time:
676
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the back plate on a Toshiba Portege R705-P35 laptop. This is a prerequisite guide to replace internal components like the fan, DVD drive and Wi-Fi card. It is necessary to remove all the back plate screws; be sure to separate the different sizes of screws for easy reinstallation.
    1. Toshiba Portege R705-P35 Back Plate Replacement, Battery: step 1, image 1 of 1
      • Turn off and unplug the laptop.
      • Failure to turn off and unplug the cable could result in electric shock.
      • Place the laptop upside-side-down with the hinges towards you.
      Ask FixBot
    2. Toshiba Portege R705-P35 Back Plate Replacement: step 2, image 1 of 1
      • Use your right hand to move the right switch from the locked position to the unlocked position.
      • Use your left hand to move the left switch from the locked position to the unlocked position.
      Ask FixBot
    3. Toshiba Portege R705-P35 Back Plate Replacement: step 3, image 1 of 2 Toshiba Portege R705-P35 Back Plate Replacement: step 3, image 2 of 2
      • While keeping the left switch unlocked, pull the battery away from the computer with your right hand.
      Ask FixBot
    1. Toshiba Portege R705-P35 Back Plate Replacement, RAM Plate: step 4, image 1 of 3 Toshiba Portege R705-P35 Back Plate Replacement, RAM Plate: step 4, image 2 of 3 Toshiba Portege R705-P35 Back Plate Replacement, RAM Plate: step 4, image 3 of 3
      • Loosen the two captive screws in the plate with a Phillips #00 screwdriver.
      • Remove the plate from the laptop.
      Ask FixBot
    1. Toshiba Portege R705-P35 Back Plate Replacement, Hard Drive Plate: step 5, image 1 of 1
      • Loosen the two captive screws in the hard drive plate using a Phillips #00 screwdriver.
      Ask FixBot
    2. Toshiba Portege R705-P35 Back Plate Replacement: step 6, image 1 of 2 Toshiba Portege R705-P35 Back Plate Replacement: step 6, image 2 of 2
      • Use your hands to remove the hard drive plate from the laptop.
      Ask FixBot
    1. Toshiba Portege R705-P35 Back Plate Replacement, Back Plate: step 7, image 1 of 1
      • Remove the two 13 mm screws from the back plate using a Phillips #0 screwdriver.
      Ask FixBot
    2. Toshiba Portege R705-P35 Back Plate Replacement: step 8, image 1 of 2 Toshiba Portege R705-P35 Back Plate Replacement: step 8, image 2 of 2
      • Lift and remove the small plate from the laptop.
      Ask FixBot
    3. Toshiba Portege R705-P35 Back Plate Replacement: step 9, image 1 of 1
      • Remove the thirteen 6 mm screws from the back plate using a Phillips #00 screwdriver.
      • Remove the five 5 mm screws from the back plate using a Phillips #00 screwdriver.
      Ask FixBot
    4. Toshiba Portege R705-P35 Back Plate Replacement: step 10, image 1 of 2 Toshiba Portege R705-P35 Back Plate Replacement: step 10, image 2 of 2
      • Pull the back plate off, starting from the right side, being cautious of the ports on the left side.
      Ask FixBot
Author
with
Kathryn Hockenbury
833 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 61
All Time: 676
