Introduction
Use this guide to remove or replace the Note's USB board/daughterboard
Parts
No parts specified.
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Slide the SIM card out the rest of the way with your thumb and remove it from the device.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to carefully disconnect the display cable connector.
Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
51 other people completed this guide.
6 Comments
It's not necessary to remove the motherboard (steps 17 and 18) to complete this repair. The flat flex running to the USB board can be easily slid out from under the motherboard with the motherboard still in position. Just omit steps 17 and 18 and the rest of the procedure works fine. I've done it twice.
Where in England could I buy the USB Board part?
USB board bought off ebay. Didnt need plastic opening tools, thumb nail worked easier than expected.
It's not the Galaxy Note GT-N7000!
Make sure to match the rev on the board! Now I can finally enjoy using the phone while plugged in again.
