Samsung Galaxy Note Motherboard Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Samsung Galaxy Note Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 1 of 2 Samsung Galaxy Note Motherboard Assembly Replacement, Motherboard Assembly: step 1, image 2 of 2
      • Use the flat end of a spudger to carefully disconnect the display cable connector.
      Ask FixBot
    2. Samsung Galaxy Note Motherboard Assembly Replacement: step 2, image 1 of 3 Samsung Galaxy Note Motherboard Assembly Replacement: step 2, image 2 of 3 Samsung Galaxy Note Motherboard Assembly Replacement: step 2, image 3 of 3
      • Use a spudger to disconnect the front-facing camera assembly cable connector.
      • Disconnect the headphone jack/earpiece speaker assembly cable connector.
      • Disconnect the digitizer cable connector.
      Ask FixBot
    3. Samsung Galaxy Note Motherboard Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy Note Motherboard Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy Note Motherboard Assembly Replacement: step 3, image 3 of 3
      • Disconnect the soft button cable connector with the flat end of a spudger.
      • Use a spudger to disconnect the USB board cable connector.
      • Disconnect the antenna cable connector.
      Ask FixBot
    4. Samsung Galaxy Note Motherboard Assembly Replacement: step 4, image 1 of 1
      • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
      Ask FixBot
    5. Samsung Galaxy Note Motherboard Assembly Replacement: step 5, image 1 of 2 Samsung Galaxy Note Motherboard Assembly Replacement: step 5, image 2 of 2
      • Remove the motherboard assembly from the display assembly.
      Ask FixBot
Sam Goldheart
478,450 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 18
All Time: 289
