Samsung Galaxy Note II Midframe Replacement
  1. Samsung Galaxy Note II Midframe Replacement, Stylus: step 1, image 1 of 2 Samsung Galaxy Note II Midframe Replacement, Stylus: step 1, image 2 of 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note II Midframe Replacement, Rear Case: step 2, image 1 of 2 Samsung Galaxy Note II Midframe Replacement, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Samsung Galaxy Note II Midframe Replacement: step 3, image 1 of 3 Samsung Galaxy Note II Midframe Replacement: step 3, image 2 of 3 Samsung Galaxy Note II Midframe Replacement: step 3, image 3 of 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Samsung Galaxy Note II Midframe Replacement, MicroSD Card: step 4, image 1 of 3 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: step 4, image 2 of 3 Samsung Galaxy Note II Midframe Replacement, MicroSD Card: step 4, image 3 of 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Samsung Galaxy Note II Midframe Replacement, Battery: step 5, image 1 of 2 Samsung Galaxy Note II Midframe Replacement, Battery: step 5, image 2 of 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Samsung Galaxy Note II Midframe Replacement: step 6, image 1 of 1
    • Remove the battery from the midframe.
  7. Samsung Galaxy Note II Midframe Replacement, Midframe: step 7, image 1 of 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Samsung Galaxy Note II Midframe Replacement: step 8, image 1 of 3 Samsung Galaxy Note II Midframe Replacement: step 8, image 2 of 3 Samsung Galaxy Note II Midframe Replacement: step 8, image 3 of 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Samsung Galaxy Note II Midframe Replacement: step 9, image 1 of 3 Samsung Galaxy Note II Midframe Replacement: step 9, image 2 of 3 Samsung Galaxy Note II Midframe Replacement: step 9, image 3 of 3
    • Continue to run the plastic opening tool down the seam.
  10. Samsung Galaxy Note II Midframe Replacement: step 10, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 10, image 2 of 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Samsung Galaxy Note II Midframe Replacement: step 11, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 11, image 2 of 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Samsung Galaxy Note II Midframe Replacement: step 12, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 12, image 2 of 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Samsung Galaxy Note II Midframe Replacement: step 13, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 13, image 2 of 2
    • Free the clips along the power button side of the phone.
    • Lastly, there are two clips along the top and bottom edge of battery compartment that also hold the display assembly in place.
    • Gently lift the clips with the spudger.
    • The display assembly should pop out from the frame.
  14. Samsung Galaxy Note II Midframe Replacement: step 14, image 1 of 2 Samsung Galaxy Note II Midframe Replacement: step 14, image 2 of 2
    • Lift the display assembly out of the midframe.
Sam Goldheart
466,153 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,420 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 30,348
