Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly
  1. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Stylus: step 1, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Stylus: step 1, image 2 of 2
    • Grasp the end of the stylus and remove it from its slot in the midframe.
  2. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Rear Case: step 2, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  3. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 3, image 1 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 3, image 2 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 3, image 3 of 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  4. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, MicroSD Card: step 4, image 1 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, MicroSD Card: step 4, image 2 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, MicroSD Card: step 4, image 3 of 3
    • If you have an SD card inserted, use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  5. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Battery: step 5, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Battery: step 5, image 2 of 2
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
  6. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 6, image 1 of 1
    • Remove the battery from the midframe.
  7. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Midframe: step 7, image 1 of 1
    • Remove the eleven 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
  8. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 8, image 1 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 8, image 2 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 8, image 3 of 3
    • Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
    • Slide the plastic opening tool down the seam.
  9. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 9, image 1 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 9, image 2 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 9, image 3 of 3
    • Continue to run the plastic opening tool down the seam.
  10. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 10, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 10, image 2 of 2
    • Carefully pry around the corner with a plastic opening tool.
  11. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 11, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 11, image 2 of 2
    • Pry along the top of the phone with a plastic opening tool.
  12. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 12, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 12, image 2 of 2
    • Push the plastic opening tool down to free the corner of the midframe from the display assembly.
  13. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 13, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 13, image 2 of 2
    • Free the clips along the power button side of the phone.
    • Lastly, free the two clips along the top and bottom edge of battery compartment.
  14. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 14, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 14, image 2 of 2
    • Lift the display assembly out of the midframe.
  15. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Motherboard Assembly: step 15, image 1 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Motherboard Assembly: step 15, image 2 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Motherboard Assembly: step 15, image 3 of 3
    • Use a spudger to disconnect the vibrator/power button assembly cable connector.
    • Disconnect the antenna cable connector.
    • Disconnect the display cable connector.
  16. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 16, image 1 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 16, image 2 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 16, image 3 of 3
    • Disconnect the front-facing camera cable connector.
    • Disconnect the headphone jack cable connector.
    • Disconnect the digitizer cable connector.
  17. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 17, image 1 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 17, image 2 of 3 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 17, image 3 of 3
    • Use the spudger to disconnect the antenna cable connector from the motherboard.
    • Disconnect the soft button cable connector.
    • Disconnect the USB board cable connector.
  18. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 18, image 1 of 1
    • Remove the 3 mm Phillips #00 screw securing the motherboard to the display assembly.
  19. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 19, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 19, image 2 of 2
    • Gently remove the motherboard.
    • Hold the motherboard by its edges to prevent ESD damage. Be careful not to snag it on any cables as you extract it from the display assembly.
  20. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly, Headphone Jack/Earpiece Speaker Assembly: step 20, image 1 of 1
    • Remove the 3 mm Phillips #00 screw securing the headphone jack assembly to the display assembly.
  21. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 21, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 21, image 2 of 2
    • Grasp the headphone jack portion of the assembly and lift it out of its groove in the display assembly.
  22. Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 22, image 1 of 2 Replacing Samsung Galaxy Note II Headphone Jack/Earpiece Speaker Assembly: step 22, image 2 of 2
    • Gently pull the headphone jack straight up without twisting the cable to remove the earpiece speaker portion from its recess.
    • Twisting or pulling unevenly could damage the cable. Be very careful as you extract the assembly.
Sam Goldheart
466,106 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,382 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 29
All Time: 57,470
