Introduction
Use this guide to replace the headphone jack and earpiece speaker assembly of your Samsung Galaxy Note.
Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
Insert your finger in the notch of the battery compartment.
Press the battery toward the rear facing camera while pulling outward.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
Slide the opening tool along the top edge of the phone.
Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly connector.
Use the point of a spudger to pry the headphone jack out of its recess in the display assembly.
Use a pair of tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly from the display assembly.
