Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly
  1. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Stylus: step 1, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Stylus: step 1, image 2 of 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Rear Case: step 2, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 3, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 3, image 2 of 2
    • Lift and remove the rear case from the phone.
  4. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Battery: step 4, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Battery: step 4, image 2 of 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, MicroSD Card: step 5, image 1 of 3 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, MicroSD Card: step 5, image 2 of 3 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, MicroSD Card: step 5, image 3 of 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 6, image 1 of 1
    • Remove the microSD card from its slot in the midframe.
  7. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, SIM Card: step 7, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, SIM Card: step 7, image 2 of 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 8, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 8, image 2 of 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Midframe: step 9, image 1 of 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 10, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 10, image 2 of 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 11, image 1 of 3 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 11, image 2 of 3 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 11, image 3 of 3
    • Slide the plastic opening tool down the seam.
  12. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 12, image 1 of 3 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 12, image 2 of 3 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 12, image 3 of 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 13, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 13, image 2 of 2
    • Remove the midframe from the display assembly.
  14. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Upper Display Assembly Bracket: step 14, image 1 of 1
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
  15. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 15, image 1 of 1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  16. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 16, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 16, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  17. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly, Headphone Jack/Earpiece Speaker Assembly: step 17, image 1 of 1
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly connector.
  18. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 18, image 1 of 2 Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 18, image 2 of 2
    • Use the point of a spudger to pry the headphone jack out of its recess in the display assembly.
  19. Replacing Samsung Galaxy Note Headphone Jack/Earpiece Speaker Assembly: step 19, image 1 of 1
    • Use a pair of tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly from the display assembly.
Sam Goldheart
466,490 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 20,396
