Replacing Samsung Galaxy Note Front Facing Camera Assembly
  1. Replacing Samsung Galaxy Note Front Facing Camera Assembly, Stylus: step 1, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly, Stylus: step 1, image 2 of 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Replacing Samsung Galaxy Note Front Facing Camera Assembly, Rear Case: step 2, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly, Rear Case: step 2, image 2 of 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 3, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 3, image 2 of 2
    • Lift and remove the rear case from the phone.
  4. Replacing Samsung Galaxy Note Front Facing Camera Assembly, Battery: step 4, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly, Battery: step 4, image 2 of 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Replacing Samsung Galaxy Note Front Facing Camera Assembly, MicroSD Card: step 5, image 1 of 3 Replacing Samsung Galaxy Note Front Facing Camera Assembly, MicroSD Card: step 5, image 2 of 3 Replacing Samsung Galaxy Note Front Facing Camera Assembly, MicroSD Card: step 5, image 3 of 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 6, image 1 of 1
    • Remove the microSD card from its slot in the midframe.
  7. Replacing Samsung Galaxy Note Front Facing Camera Assembly, SIM Card: step 7, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly, SIM Card: step 7, image 2 of 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 8, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 8, image 2 of 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Replacing Samsung Galaxy Note Front Facing Camera Assembly, Midframe: step 9, image 1 of 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 10, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 10, image 2 of 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 11, image 1 of 3 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 11, image 2 of 3 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 11, image 3 of 3
    • Slide the plastic opening tool down the seam.
  12. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 12, image 1 of 3 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 12, image 2 of 3 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 12, image 3 of 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 13, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 13, image 2 of 2
    • Remove the midframe from the display assembly.
  14. Replacing Samsung Galaxy Note Front Facing Camera Assembly, Upper Display Assembly Bracket: step 14, image 1 of 1
    • Use the flat end of a spudger to disconnect the headphone jack/earpiece speaker assembly cable connector.
  15. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 15, image 1 of 1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  16. Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 16, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly: step 16, image 2 of 2
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  17. Replacing Samsung Galaxy Note Front Facing Camera Assembly, Front Facing Camera Assembly: step 17, image 1 of 2 Replacing Samsung Galaxy Note Front Facing Camera Assembly, Front Facing Camera Assembly: step 17, image 2 of 2
    • Using tweezers, or your fingers, remove the front-facing camera assembly.
Sam Goldheart
465,854 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,198 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 18
All Time: 5,197
