Shop the Holiday Gift Guide
Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement
Views: 16K
View statistics:
Past 24 Hours:
2
Past 7 Days:
40
Past 30 Days:
158
All Time:
16,265
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If you determine that your vacuum is no longer picking up debris, this guide will help you to replace the washable filters to increase the suction.
    1. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement, Washable Filters: step 1, image 1 of 2 Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement, Washable Filters: step 1, image 2 of 2
      • Press the grey dust cup release button and gently pull the dust cup towards you.
      Ask FixBot
    2. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: step 2, image 1 of 2 Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: step 2, image 2 of 2
      • Lift the latch on the top of the dust cup cover to open. You can now see the foam filter inside the cyclone portion of the dust cup.
      Ask FixBot
    3. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: step 3, image 1 of 1
      • Remove the white filter by lifting the gray foam filter handle.
      Ask FixBot
    4. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: step 4, image 1 of 1
      • Push the white mesh, segment below the filter handle downward so it pops out of the grey filter holder. This will remove the filter.
      Ask FixBot
    5. Eureka AirSpeed Bagless Zuum Vacuum Washable Filters Replacement: step 5, image 1 of 1
      • If filter is unable to be washed, place a new filter in gray holder.
      Ask FixBot
Author
with
Celina Burchett
1,122 Reputation
8 Guides authored
Clemson, Team 2-2, Benson Fall 2014 Member of Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 Members
96 Guides authored
1 Guide Comment
Can you wash the white filter within the grey holder?
Lloyd C - Reply Share
Past 24 Hours: 2
Past 7 Days: 40
Past 30 Days: 158
All Time: 16,265
