Introduction
The power and volume buttons are responsible for turning your tablet on or changing the volume of your tablet. If the tablet doesn't respond to pressing any of those buttons, it is likely that the buttons are jammed or worn out from use. In order to resolve such issues, you'll have to replace the strip that holds the power and volume buttons. This guide shows you how to replace that strip.
Using the plastic opening tool, start where the S-pen was located and carefully pry up the corner.
Work your way around the entire device by carefully prying and sliding the plastic opening tool.
Gently grasp and lift up the white connector located at the bottom right corner of the battery. It is connected to the battery by two blue and two red wires.
The volume and power buttons are joined together on a common strip, so you are replacing both simultaneously.
Disconnect the black connector by pulling up using a plastic opening tool underneath the edge. This connection attaches the power/volume cable to the mother board.
Remove the 3-mm screw holding the upper left corner of the main board using a Phillips#00 screwdriver.
Gently pry the middle of the cable up and off of the two plastic studs.
Gently pry the part of the cable adjacent to the power button up and off the two plastics studs.
Gently pry the upper part of the cable up and off the two plastic studs.
Using tweezers, pull the part of the cable that is located behind the volume buttons out of the slot.
