Samsung Galaxy Note 4 Motherboard Replacement
  1. Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: step 1, image 1 of 2 Samsung Galaxy Note 4 Motherboard Replacement, Rear Case: step 1, image 2 of 2
    • Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera.
    • Gently pry and twist the flexible rear cover off the back of the phone.
  2. Samsung Galaxy Note 4 Motherboard Replacement, Battery: step 2, image 1 of 1
    • Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
    • Remove the battery.
  3. Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: step 3, image 1 of 2 Samsung Galaxy Note 4 Motherboard Replacement, SIM Card: step 3, image 2 of 2
    • Remove the SIM card by first pushing the card slightly out of its housing, then pulling it the rest of the way.
  4. Samsung Galaxy Note 4 Motherboard Replacement, Midframe: step 4, image 1 of 1
    • Remove the sixteen 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
    • Grasp the cap of the S Pen and remove it from its slot in the midframe.
  5. Samsung Galaxy Note 4 Motherboard Replacement: step 5, image 1 of 3 Samsung Galaxy Note 4 Motherboard Replacement: step 5, image 2 of 3 Samsung Galaxy Note 4 Motherboard Replacement: step 5, image 3 of 3
    • Insert a plastic opening tool between the midframe and the display assembly.
    • Work the plastic opening tool around the perimeter of the phone to break the adhesive.
    • This adhesive is relatively weak, so no heat gun should be necessary.
    • Be careful to not separate the front glass panel from the rest of the display assembly, as it is still held together with adhesive.
  6. Samsung Galaxy Note 4 Motherboard Replacement: step 6, image 1 of 1
    • Use a plastic opening tool to loosen the clasps around the battery housing.
  7. Samsung Galaxy Note 4 Motherboard Replacement: step 7, image 1 of 3 Samsung Galaxy Note 4 Motherboard Replacement: step 7, image 2 of 3 Samsung Galaxy Note 4 Motherboard Replacement: step 7, image 3 of 3
    • Push on the battery housing to separate the midframe from the display assembly.
    • You will have to apply a reasonable amount of pressure to separate the two parts.
    • If your new midframe does not come with a headphone jack assembly, you'll need to transfer the one from the old midframe into the new one. It can be pried loose with plastic opening tools, as it is held in place with several plastic pins.
  8. Samsung Galaxy Note 4 Motherboard Replacement, Motherboard: step 8, image 1 of 1
    • Remove the two 2.9 mm Phillips #00 screws.
  9. Samsung Galaxy Note 4 Motherboard Replacement: step 9, image 1 of 2 Samsung Galaxy Note 4 Motherboard Replacement: step 9, image 2 of 2
    • Use a set of tweezers to remove the two antenna cables.
  10. Samsung Galaxy Note 4 Motherboard Replacement: step 10, image 1 of 3 Samsung Galaxy Note 4 Motherboard Replacement: step 10, image 2 of 3 Samsung Galaxy Note 4 Motherboard Replacement: step 10, image 3 of 3
    • Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
  11. Samsung Galaxy Note 4 Motherboard Replacement: step 11, image 1 of 1
    • Gently lift the motherboard out of the phone.
Geoff Wacker
90,075 Reputation
89 Guides authored
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 118
All Time: 146,625
