Homelite UT44172 Blades Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
93
All Time:
1,310
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If you are having trouble with your Homelite UT44172 Cordless Grass Shear cutting grass due to dull, loose, or broken blades, follow this guide to replace them.
Tools
    1. Homelite UT44172 Blades Replacement, Removing Screws: step 1, image 1 of 1
      • Remove the six 15.0 mm screws from the body of the device with a Phillips #2 screwdriver.
      Ask FixBot
    2. Homelite UT44172 Blades Replacement, Removing Faceplate: step 2, image 1 of 1
      • Remove the face plate by lifting it away from the other half of the device. This will expose the interior.
      Ask FixBot
    3. Homelite UT44172 Blades Replacement, Exposing Blade Components: step 3, image 1 of 2 Homelite UT44172 Blades Replacement, Exposing Blade Components: step 3, image 2 of 2
      • Use the Phillips #2 screwdriver to remove the four 10.0 mm screws on the bottom of the blades.
      Ask FixBot
    4. Homelite UT44172 Blades Replacement, Replacing Blades: step 4, image 1 of 3 Homelite UT44172 Blades Replacement, Replacing Blades: step 4, image 2 of 3 Homelite UT44172 Blades Replacement, Replacing Blades: step 4, image 3 of 3
      • Remove the old blades by pulling them away from the gears and motor.
      • Be careful handling the blades. They are sharp.
      Ask FixBot
Adam soto
301 Reputation
3 Guides authored
USF Tampa, Team 17-5, Watkins Winter 2015 Member of USF Tampa, Team 17-5, Watkins Winter 2015
USFT-WATKINS-W15S17G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 93
All Time: 1,310
