Samsung Galaxy Note 10.1 Charging Port Replacement
  1. Samsung Galaxy Note 10.1 Charging Port Replacement, Charging Port: step 1, image 1 of 3 Samsung Galaxy Note 10.1 Charging Port Replacement, Charging Port: step 1, image 2 of 3 Samsung Galaxy Note 10.1 Charging Port Replacement, Charging Port: step 1, image 3 of 3
    • This is the back of the device and where you will begin to take it apart.
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use a metal spudger to pop up the corner of the silver piece.
    • Use the plastic opening tools to pry along the edges of the silver piece.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Charging Port Replacement: step 2, image 1 of 3 Samsung Galaxy Note 10.1 Charging Port Replacement: step 2, image 2 of 3 Samsung Galaxy Note 10.1 Charging Port Replacement: step 2, image 3 of 3
    • Remove the three 5mm screws indicated by the red circles with the Philips #00 Screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Charging Port Replacement: step 3, image 1 of 3 Samsung Galaxy Note 10.1 Charging Port Replacement: step 3, image 2 of 3 Samsung Galaxy Note 10.1 Charging Port Replacement: step 3, image 3 of 3
    • Remove the three 2 mm screws indicated by the red circles with the Phillips #00 screwdriver.
    • Pull the charging port indicated by the orange rectangle in picture two out from its position.
    • Unplug the black motherboard connector as indicated in the third picture.
    • Replace the charging port with a similar model.
Gavin Tipker
193 Reputation
2 Guides authored
IUPUI, Team S3-G1, Harley Fall 2018 Member of IUPUI, Team S3-G1, Harley Fall 2018
IUPUI-HARLEY-F18S3G1
3 Members
2 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 25
All Time: 3,122
