Introduction
This guide will walk you through the process of replacing a not working power button in a Samsung Galaxy J3V.
Place your thumb on the top left corner and pry the tab open and lift off the back cover.
Use a small suction cup to pull the screen up. Then slip a small plastic opening tool under the screen to pry it upwards.
Using tweezers, remove the power button's rubber tabs from the clips holding them.
Gently remove the entire button
