Introduction
Use this guide to replace the battery and SIM card on your Samsung Galaxy J3 Prime smartphone. The battery of any smartphone is very critical. It depletes with time, preventing your phone to work at its full potential. The worn-out battery can cause your phone to run out of power within minutes even though you have charged it to 100%.
A battery is meant to give power to your phone. But, over time, charging your battery reduces its performance. We are consistently charging our phones batteries, which isn’t ideal in the long run.
This guide is simple to follow as you will not need any screwdrivers or tools, as your hand gets the job done.
In step 1 of this guide, you will need to power off your phone completely. Also, make sure to remove any external devices plugged in and avoid the presence of water.
Power off your phone by holding down the power button; located on the top right-hand side of your phone for approximately 5 seconds.
One Comment
I need to replace the sim card slot on one of these is it individual or does it come out with the whole motherbord and what parts do I need to order?
