Midframe
  1. Midframe, Midframe: step 1, image 1 of 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Midframe: step 2, image 1 of 2 Midframe: step 2, image 2 of 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
  3. Midframe: step 3, image 1 of 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Midframe: step 4, image 1 of 3 Midframe: step 4, image 2 of 3 Midframe: step 4, image 3 of 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
Sean Kramer
1,506 Reputation
6 Guides authored
USF Tampa, Team S5-G4, Eyestone Spring 2018 Member of USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Members
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 24
All Time: 2,139
