Samsung Galaxy J1 Glass Screen Replacement
  1. Samsung Galaxy J1 Glass Screen Replacement, Midframe: step 1, image 1 of 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Glass Screen Replacement: step 2, image 1 of 2 Samsung Galaxy J1 Glass Screen Replacement: step 2, image 2 of 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Glass Screen Replacement: step 3, image 1 of 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Glass Screen Replacement: step 4, image 1 of 3 Samsung Galaxy J1 Glass Screen Replacement: step 4, image 2 of 3 Samsung Galaxy J1 Glass Screen Replacement: step 4, image 3 of 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: step 5, image 1 of 2 Samsung Galaxy J1 Glass Screen Replacement, Glass Screen: step 5, image 2 of 2
    • Using the flat end of a spudger, disconnect the digitizer cable connector.
  6. Samsung Galaxy J1 Glass Screen Replacement: step 6, image 1 of 2 Samsung Galaxy J1 Glass Screen Replacement: step 6, image 2 of 2
    • Using a plastic opening tool pry between silver digitizer and black back piece.
    • Slowly slide plastic opening tool around the screen to loosen the adhesive.
    • Be careful not to tear the digitizer cable when threading it through the plastic housing.
  7. Samsung Galaxy J1 Glass Screen Replacement: step 7, image 1 of 1
    • Carefully separate display assembly from the plastic housing.
19 other people completed this guide.
Sean Kramer
1,467 Reputation
6 Guides authored
USF Tampa, Team S5-G4, Eyestone Spring 2018 Member of USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 Members
6 Guides authored
2 Comments
In my Samsung J110h, Some of the right side keys in keyboard not working. They are P, Zero, In message screen, the sending button etc..
I am in desperate need for advice to rectify.
Will somebody help me.
My mail Id”: karupusolai@gmail.com
Solaimalai - Reply
I was having the display issue. So I bought Samsung Galaxy J1 Screen replacement. And, I replaced it by myself using the information in this.
harshithaemazel - Reply
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 61
All Time: 4,725
