Samsung Galaxy Fame S6812i Speaker Replacement
  1. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery Cover: step 1, image 1 of 2 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery Cover: step 1, image 2 of 2
    • Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery: step 2, image 1 of 2 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Battery: step 2, image 2 of 2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Mid-Frame: step 3, image 1 of 3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Mid-Frame: step 3, image 2 of 3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Mid-Frame: step 3, image 3 of 3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Damaged Speaker: step 4, image 1 of 3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Damaged Speaker: step 4, image 2 of 3 Samsung Galaxy Fame S6812i Speaker Replacement, Remove the Damaged Speaker: step 4, image 3 of 3
    • Lift the speaker from the phone using your fingers or tweezers.
Taylor
1,165 Reputation
5 Guides authored
USF Tampa, Team 16-6, Watkins Winter 2015 Member of USF Tampa, Team 16-6, Watkins Winter 2015
USFT-WATKINS-W15S16G6
2 Members
5 Guides authored
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 8
All Time: 849
