Samsung Galaxy Fame S6812i Midframe Replacement
  1. Samsung Galaxy Fame S6812i Midframe Replacement, Remove back cover: step 1, image 1 of 1
    • Start by removing the back cover by using your thumbnail to pry the cover off the midframe.
  2. Samsung Galaxy Fame S6812i Midframe Replacement: step 2, image 1 of 3 Samsung Galaxy Fame S6812i Midframe Replacement: step 2, image 2 of 3 Samsung Galaxy Fame S6812i Midframe Replacement: step 2, image 3 of 3
    • Note: one of the screws is hidden under a plastic sticker.
    • Remove the five 4 mm screws with a Phillips#00 screwdriver.
  3. Samsung Galaxy Fame S6812i Midframe Replacement: step 3, image 1 of 1
    • Remove the battery with plastic opening tool
  4. Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: step 4, image 1 of 2 Samsung Galaxy Fame S6812i Midframe Replacement, Separating the midframe: step 4, image 2 of 2
    • Using the plastic opening tool pry into the bezel to remove the mid-frame
    • Continue moving the plastic opening tool around the mid-frame to separate it from the display assembly.
    • Be gentle the plastic mounting clips are very fragile. Pay extra attention when working around the volume button.
  5. Samsung Galaxy Fame S6812i Midframe Replacement, Final step: step 5, image 1 of 1
    • Once you have separated the mid-frame it should look like this.
    • Replace the old mid-frame with the new one and follow the steps in reverse.
Charles
133 Reputation
2 Guides authored
USF Tampa, Team 8-2, Leahy Fall 2014 Member of USF Tampa, Team 8-2, Leahy Fall 2014
USFT-LEAHY-F14S8G2
4 Members
5 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 576
