Samsung Galaxy Book Pro 15" Screen Replacement
    1. Samsung Galaxy Book Pro 15" Screen Replacement, Screen: step 1, image 1 of 1
      • Lcd is physically damaged. Time to replace!
      Ask FixBot
    2. Samsung Galaxy Book Pro 15" Screen Replacement: step 2, image 1 of 1
      • This repair is similar to most other laptops in that you have to remove the bezel around the screen. Unlike most laptops however, it's easier to go under the bezel from the screen side. If you're doing this on a screen that is not broken use more care than I did here
      Ask FixBot
    3. Samsung Galaxy Book Pro 15" Screen Replacement: step 3, image 1 of 1
      • Be very careful pulling this bezel off, it is metal and will bend. As long as it doesn't bend too much some new adhesive will hold it down fine once the repair is finished.
      Ask FixBot
    4. Samsung Galaxy Book Pro 15" Screen Replacement: step 4, image 1 of 2 Samsung Galaxy Book Pro 15" Screen Replacement: step 4, image 2 of 2
      • Take note of the small black squares, they are small soft foam pads. These attach to the adhesive strips that hold the screen in.
      Ask FixBot
    5. Samsung Galaxy Book Pro 15" Screen Replacement: step 5, image 1 of 3 Samsung Galaxy Book Pro 15" Screen Replacement: step 5, image 2 of 3 Samsung Galaxy Book Pro 15" Screen Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Grab the adhesive strip with tweezers, and slowly pull. Pull from below, working out to the side if you need to. This process is the same on both sides.
      Ask FixBot
    6. Samsung Galaxy Book Pro 15" Screen Replacement: step 6, image 1 of 1
      • Now that the screen is no longer held to the housing, it's time to separate the two. You can use a black stick or a pick here, I just used my finger nail. You may not even need to pull on it, it should just fall forward.
      Ask FixBot
    7. Samsung Galaxy Book Pro 15" Screen Replacement: step 7, image 1 of 3 Samsung Galaxy Book Pro 15" Screen Replacement: step 7, image 2 of 3 Samsung Galaxy Book Pro 15" Screen Replacement: step 7, image 3 of 3
      • The screen is now lowered, we're almost done! Get a black stick below the bar that holds the LCD connector. Pry it up gently, then it is released. Gently pull the LCD connector free
      Ask FixBot
    8. Samsung Galaxy Book Pro 15" Screen Replacement: step 8, image 1 of 1
      • You're done! Now just do the process in reverse for the new screen. Make sure to use new adhesives on the back of the screen and on the bezel.
      Ask FixBot
Joshua Woessner
157 Reputation
1 Guide authored
1 Guide Comment
where can I get the adhesive (or what kind of adhesive should I use, model?)
Alex Wang - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 97
All Time: 1,222
