Samsung Galaxy Alpha Micro USB port Replacement
    1. Samsung Galaxy Alpha Micro USB port Replacement, Removing the Back Panel: step 1, image 1 of 3 Samsung Galaxy Alpha Micro USB port Replacement, Removing the Back Panel: step 1, image 2 of 3 Samsung Galaxy Alpha Micro USB port Replacement, Removing the Back Panel: step 1, image 3 of 3
      • On the back panel of the phone, find the slot that is on the top left side next to the flashlight.
      • Insert your fingernail or prying tool into the slot and lift up to slightly open the top left corner of the back panel.
      • Slide your fingernail or prying tool around the outer edge of the back panel to fully release it from the phone.
      Ask FixBot
    1. Samsung Galaxy Alpha Micro USB port Replacement, Battery: step 2, image 1 of 2 Samsung Galaxy Alpha Micro USB port Replacement, Battery: step 2, image 2 of 2
      • Make sure the device is powered down before moving forward.
      • Since the NFC antenna is glued to the battery, make sure the replacement also includes one.
      • Locate the slot at the base of the battery and insert your thumb.
      • Push slightly toward the battery and out, away from the phone to free the battery.
      Ask FixBot
Ryan Butler
1,924 Reputation
9 Guides authored
iFixit, Team 1-1, Weber Winter 2016 Member of iFixit, Team 1-1, Weber Winter 2016
FIX-WEBER-W16S1G1
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 105
All Time: 675
