Samsung Galaxy A36 Disassembly
      • Apply Heat: Use a hair dryer, heat gun, or a heated rice bag (like an iOpener). Focus on the outer edges of the back glass for 2-3 minutes. Tip: The glass should be quite warm to the touch, but not so hot that it burns your skin or melts the plastic frame.
      • Attach Suction: Place a suction cup on the bottom half of the back glass, as close to the edge as possible.
      • Create a Gap: Pull up on the suction cup with steady, firm pressure to create a tiny gap between the glass and the frame.
      • Insert a Pick: Slide a thin plastic opening pick (or a guitar pick) into that tiny gap.
      Ask FixBot
      • Slide the Pick: Slowly slide your pick along the bottom edge of the phone. Note: If the glue feels "grabby" or tough, apply more heat.
      • Navigate the Corners: Carefully slide around the corners. Leave a pick in each corner as you go to prevent the glue from re-sticking.
      • Watch the "Key Island": When sliding along the right side (where the power and volume buttons are), do not insert your pick deeper than 5mm. There are delicate ribbon cables there that can be easily sliced.
      • Finish the Loop: Continue sliding until you have cut the glue around all four sides.
      Ask FixBot
      • Open Slowly: Use your pick to gently pry the back cover up.
      • Final Check: If the cover feels stuck, don't force it. Re-insert a pick and check for any spots of glue you might have missed.
      • Remove: Once the glue is fully cut, lift the back cover off and set it aside in a safe, dust-free place.
      Ask FixBot
Cameron Bates
127 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 66
Past 30 Days: 256
All Time: 549
