Samsung Galaxy A20e Display Replacement
  1. Samsung Galaxy A20e Display Replacement, Display: step 1, image 1 of 2 Samsung Galaxy A20e Display Replacement, Display: step 1, image 2 of 2
    • Remove the SIM and MicroSD tray.
    please put A20e as main heading not A20
    Fix it phones dorchester - Reply
  2. Samsung Galaxy A20e Display Replacement: step 2, image 1 of 2 Samsung Galaxy A20e Display Replacement: step 2, image 2 of 2
    • Release the back cover with the help of a thin blade or a Jimmy. Insert the tool between the frame display and the cover unclipping it along the entire perimeter.
    • Insert a Jimmy between the display frame and the side shell and slide it along the edge, in order to completely disengage the two parts.
    • Be careful if you use a Jimmy as they are made of metal and make breaking internal components very easy. It is preferable to use a plastic utensil.
  3. Samsung Galaxy A20e Display Replacement: step 3, image 1 of 1
    • Disconnect the Fingerprint scanner.
  4. Samsung Galaxy A20e Display Replacement: step 4, image 1 of 1
    • Using a Philips #00 screwdriver, remove the 13 screws securing the inner cover.
  5. Samsung Galaxy A20e Display Replacement: step 5, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 5, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 5, image 3 of 3
    • Now you can remove the upper and lower covers that protect the logic board and the speaker respectively.
  6. Samsung Galaxy A20e Display Replacement: step 6, image 1 of 2 Samsung Galaxy A20e Display Replacement: step 6, image 2 of 2
    • Pry up the following four connectors:
    • Battery connector;
    • Display connector;
    • Power / volume buttons;
    • Lower logic board connector.
    • The lower logic board ribbon cable must be disconnected from the lower board as well before proceeding with the next steps.
    • There is an arrow on the ribbon cable connecting the lower board with the logic board. When reinstalling it, this arrow must point towards the main board.
    geht gut wenn man eine alte Kreditkarte unter den Akku schiebt.
    A V - Reply
  7. Samsung Galaxy A20e Display Replacement, Remove The Battery: step 7, image 1 of 1
    • Remove the battery by placing a few drops of alcohol underneath the battery and letting it sit for about a minute. This will weaken the double-sided adhesive that holds the battery.
    • If you notice that it wasn't enough, and you need to use too much force, with the risk of bending or damaging the battery, apply more alcohol.
    • Never puncture or bend the battery.
    • During reassembly, remember to apply new double-sided tape to hold the battery in place.
  8. Samsung Galaxy A20e Display Replacement: step 8, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 8, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 8, image 3 of 3
    • Disconnect the two blue and white antenna wires.
    • Remember the locations of these wires when you reassemble the phone.
    • Remove the motherboard by lifting it away by the upper part.
    • Carefully remove the microphone, as it is glued and easily damaged. Try to warm up that area a little to make it easier.
    Mais pourquoi tu me montes
    Mahamoud Diaby - Reply
  9. Samsung Galaxy A20e Display Replacement: step 9, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 9, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 9, image 3 of 3
    • Remove the glued-on vibration motor with the help of a small amount of heat
    • Remove the lower motherboard.
    • Remove the glued-on speaker with the help of a heat source.
    hier ist noch eine vierte Schraube zu lösen.
    A V - Reply
  10. Samsung Galaxy A20e Display Replacement: step 10, image 1 of 3 Samsung Galaxy A20e Display Replacement: step 10, image 2 of 3 Samsung Galaxy A20e Display Replacement: step 10, image 3 of 3
    • Once you have completed the component removal, you can begin the reassembly by placing the components on the new display.
    what do u mean by remove the power/volume flat and separate plastic from display
    Georgie Sheridan - Reply
    Ciao,
    significa che devi sganciare i connettori dei rispettivi collegamenti
    Smilzo -
16 other people completed this guide.
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Smilzo
11,267 Reputation
39 Guides authored
12 Comments
this guide isn’t for a A20 its for an A20e
CPR Jackson TN - Reply
Ciao,il codice completo è A20E SM-A202f .
se cerchi questo codice nelle guide riparazione trovi telefono-Android-Samsung-A- A20e SM-A202f trovi la mia guida del display. Non posso nominarla come la cartella genitore,non so se questo è un bug. Grazie
Smilzo -
If you're gonna re-use the battery I wouldn't use heat, it damages the cells inside of the battery. Just pry with a spudger and have
joey Van beek - Reply
I'm sorry I don't agree with a spudger without adequate heat the battery would bend to be removed. The adhesive is very resistant and the heat must be dosed appropriately for the situation so as not to damage the battery and the other components
Smilzo -
In another vid, to remove the battery “without" heat, the person used “rubbing alcohol” said it consumes the adhesive making it very easy to remove, placing it with a syringe like tip, along both the left and right sides, when the phone is in the normal upright position. And because rubbing alcohol evaporates, it's not harmful to the phone. Then a spudger can be used without brute force. That was a vid for the A205. (2019)
Becky Firestone - Reply
hello, everyone is free to use the method they prefer based on their experience.  I use heat adequately.  you use the method that gives you the most confidence.  Greetings
Smilzo -
Grazie, davvero un ottimo lavoro! Sono riuscita persino io a sostituire il display del cellulare di mia figlia. Ora è come nuovo... In attesa della prossima caduta! Se posso permettermi un piccolo commento, al passo 9 "Rimuovi la scheda logica inferiore" manca "svitando anche la vite che si trova alla destra del connettore della scheda logica inferiore", anche se dalle foto, chiarissime, si vede comunque bene che al passaggio 8 la vite c'era e al 9 non c'è più. Grazie ancora! :-)
Claudia - Reply
Onorato di essere stato utile
Smilzo -
salve, ma se devo sostituire solo il vetro?
Angelo Charlie Vitagliano - Reply
Ciao @angelocharl5424 Sfortunatamente non abbiamo nessun contenuto per sostituire soli il vetro del Samsung Galaxy A20e. Però Internet è pieno di risorse! iFixit è un wiki, quindi sei benvenuto per documentare una guida per questa riparazione quando l’avrai finita! Infine puoi aggiungere questo dispositivo alla lista di richiesta di nuove guide.
Claire Miesch -
salve,sconsiglio fortemente la sostituzione,avrebbe sicuramente un esito disastroso in quanto sono incollati insieme al display ,ci vogliono attrezzature particolare per avere una sostituzione decente. costa molto meno ed hai piu probabilita di riuscita sostituire il gruppo intero. puoio cercare qualsiasi guida qua oppure su youtube di sostituzione vetro (che sia incollato al display) per renderti conto del tipo di lavoro che richiede. saluti
Smilzo -
se monto girato il flat che si stacca si sopra che sotto, cosa succede? si bruccia solo qualcosa facilmente reperibile? grazie
Florian Falli - Reply
Past 24 Hours: 7
Past 7 Days: 55
Past 30 Days: 230
All Time: 24,313
