Samsung Galaxy A11 Display Assembly Replacement
  1. Samsung Galaxy A11 Display Assembly Replacement, Back Cover: step 1, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: step 1, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: step 1, image 3 of 3
    • Place the SIM eject tool in the hole of the sim tray.
    • Push until part of the SIM tray is pushed out.
    • Pull out the rest of the SIM tray.
  2. Samsung Galaxy A11 Display Assembly Replacement: step 2, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 2, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 2, image 3 of 3
    • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
    • Gently move the pick along the gap and pry open the clips holding it together.
    • If possible, use multiple picks to prevent the back cover from closing.
  3. Samsung Galaxy A11 Display Assembly Replacement: step 3, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 3, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 3, image 3 of 3
    • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
    • Gently push the fingerprint sensor until it detaches from the back cover.
    • If needed, remove the button by prying it from the bottom of the device.
  4. Samsung Galaxy A11 Display Assembly Replacement, Battery: step 4, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement, Battery: step 4, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement, Battery: step 4, image 3 of 3
    • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
    • Remove the shield from the phone.
  5. Samsung Galaxy A11 Display Assembly Replacement: step 5, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 5, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 5, image 3 of 3
    • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
  6. Samsung Galaxy A11 Display Assembly Replacement: step 6, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 6, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 6, image 3 of 3
    • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
    • Use an iFixit pry tool to dig under the battery edge.
    • If needed, use multiple pry tools to hold the battery in place.
    • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
    • Remove the battery from the phone.
  7. Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: step 7, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: step 7, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: step 7, image 3 of 3
    • Gently use tweezers to peel up the copper strip on the top right of the phone.
  8. Samsung Galaxy A11 Display Assembly Replacement: step 8, image 1 of 2 Samsung Galaxy A11 Display Assembly Replacement: step 8, image 2 of 2
    • Remove the three black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the cover from the phone.
  9. Samsung Galaxy A11 Display Assembly Replacement: step 9, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 9, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 9, image 3 of 3
    • Using tweezers, carefully remove the earpiece speaker at the top of the phone.
    • When using metal tools, it is important to be gentle in order to not damage the device.
    • If needed, you can use a hair dryer to apply heat to the speaker and loosen the adhesive.
    • If needed, you may orient the tweezers to your liking, gripping the earpiece horizontally or vertically, while removing it.
  10. Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: step 10, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: step 10, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: step 10, image 3 of 3
    • Using a spudger, detach the ribbon cable connected to the fingerprint sensor.
    • Remove the fingerprint sensor from the device.
  11. Samsung Galaxy A11 Display Assembly Replacement, Motherboard: step 11, image 1 of 1
    • Remove the two 3 mm silver screws from the top left of the device using a Phillips #000 screwdriver.
  12. Samsung Galaxy A11 Display Assembly Replacement: step 12, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 12, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 12, image 3 of 3
    • Using a spudger, disconnect the two ribbon cables attached to the battery slot from the motherboard.
    • Disconnect the two longer ribbon cables near the bottom right corner of the motherboard.
    • Lift these cables up slightly to reveal a gap.
  13. Samsung Galaxy A11 Display Assembly Replacement: step 13, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 13, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 13, image 3 of 3
    • Using a spudger, gently pry the motherboard up using the corner revealed in the previous step.
    • If needed, use a metal spudger as a sturdier alternative.
    • If using a metal spudger, it is important to be gentle in order to not damage any components of the device.
    • Remove the motherboard from the device.
  14. Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: step 14, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: step 14, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: step 14, image 3 of 3
    • Remove the eight silver and black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the speaker cover from the device.
  15. Samsung Galaxy A11 Display Assembly Replacement: step 15, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 15, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 15, image 3 of 3
    • Using a spudger, disconnect the antenna heads from the daughterboard.
    • Disconnect the ribbon cable from the daughterboard.
  16. Samsung Galaxy A11 Display Assembly Replacement: step 16, image 1 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 16, image 2 of 3 Samsung Galaxy A11 Display Assembly Replacement: step 16, image 3 of 3
    • Using tweezers, gently pry the daughterboard from the device.
  17. Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: step 17, image 1 of 2 Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: step 17, image 2 of 2
    • Using tweezers, remove the vibrator motor from the device.
    • If needed, you can apply heat to loosen the adhesive from the motor.
  18. Samsung Galaxy A11 Display Assembly Replacement, Display Assembly: step 18, image 1 of 1
    • The display assembly is separated from all other components and can be replaced.
4 other people completed this guide.
Chloe Bulloch
765 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 172
All Time: 2,413
