Samsung Epic 4G Battery Replacement
  1. Samsung Epic 4G Battery Replacement, Phone Case: step 1, image 1 of 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Battery Replacement: step 2, image 1 of 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Battery Replacement, Battery: step 3, image 1 of 1
    • Remove the battery from the device by pulling up on the battery edge.
Andrew Cunningham
273 Reputation
6 Guides authored
Cal Poly, Team 24-25, Regan Fall 2012 Member of Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,063
