OBSOLETE - How to Remove a stuck game from an Xbox 360
Views: 33K
View statistics:
Past 24 Hours:
5
Past 7 Days:
40
Past 30 Days:
172
All Time:
33,064
Comments: 2
2 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 82
82 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
READ ME: This guide has been archived by the author due to the age of this guide, and the fact this 360 is no longer around. I will not be updating this guide further. I have moved on from this guide but I feel like this could still help someone so I am keeping it around.
Game stuck in your Xbox 360? Here's a way that may work to remove it, in lieu of voiding the warranty (if the console is still under warranty).
Tools
    1. OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: step 1, image 1 of 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: step 1, image 2 of 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: step 1, image 3 of 3
      • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
      Ask FixBot
    2. OBSOLETE - How to Remove a stuck game from an Xbox 360, Find the emergency eject hole: step 2, image 1 of 1
      • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
      • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
      Ask FixBot
    3. OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: step 3, image 1 of 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: step 3, image 2 of 3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: step 3, image 3 of 3
      • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
      • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
      Ask FixBot
20 other people completed this guide.
Nick
106,431 Reputation
72 Guides authored
2 Guide Comments
will this work for elite 250 gug
duangphetv - Reply Share
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - Reply Share
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 172
All Time: 33,064
