Replacing Samsung DVD-P230 Tray Motor
  1. Replacing Samsung DVD-P230 Tray Motor, Outer Cover & Faceplate: step 1, image 1 of 3 Replacing Samsung DVD-P230 Tray Motor, Outer Cover & Faceplate: step 1, image 2 of 3 Replacing Samsung DVD-P230 Tray Motor, Outer Cover & Faceplate: step 1, image 3 of 3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
  2. Replacing Samsung DVD-P230 Tray Motor: step 2, image 1 of 1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Replacing Samsung DVD-P230 Tray Motor: step 3, image 1 of 1
    • Unscrew the 3 screws in the back.
  4. Replacing Samsung DVD-P230 Tray Motor: step 4, image 1 of 2 Replacing Samsung DVD-P230 Tray Motor: step 4, image 2 of 2
    • Pull the outer case upward and then towards you.
  5. Replacing Samsung DVD-P230 Tray Motor: step 5, image 1 of 3 Replacing Samsung DVD-P230 Tray Motor: step 5, image 2 of 3 Replacing Samsung DVD-P230 Tray Motor: step 5, image 3 of 3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Replacing Samsung DVD-P230 Tray Motor: step 6, image 1 of 2 Replacing Samsung DVD-P230 Tray Motor: step 6, image 2 of 2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Replacing Samsung DVD-P230 Tray Motor, Power Cord: step 7, image 1 of 3 Replacing Samsung DVD-P230 Tray Motor, Power Cord: step 7, image 2 of 3 Replacing Samsung DVD-P230 Tray Motor, Power Cord: step 7, image 3 of 3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
  8. Replacing Samsung DVD-P230 Tray Motor, Tray: step 8, image 1 of 3 Replacing Samsung DVD-P230 Tray Motor, Tray: step 8, image 2 of 3 Replacing Samsung DVD-P230 Tray Motor, Tray: step 8, image 3 of 3
    • Remove the three screws holding in the DVD tray
  9. Replacing Samsung DVD-P230 Tray Motor: step 9, image 1 of 2 Replacing Samsung DVD-P230 Tray Motor: step 9, image 2 of 2
    • Remove the power cord and first two ribbons by pulling them directly out of their sockets.
  10. Replacing Samsung DVD-P230 Tray Motor: step 10, image 1 of 2 Replacing Samsung DVD-P230 Tray Motor: step 10, image 2 of 2
    • Gently lift the DVD tray off of the motherboard.
  11. Replacing Samsung DVD-P230 Tray Motor, Tray Motor: step 11, image 1 of 2 Replacing Samsung DVD-P230 Tray Motor, Tray Motor: step 11, image 2 of 2
    • Spin the small gear shown to the right to begin opening the tray. There should be relatively little resistance in the gear.
  12. Replacing Samsung DVD-P230 Tray Motor: step 12, image 1 of 3 Replacing Samsung DVD-P230 Tray Motor: step 12, image 2 of 3 Replacing Samsung DVD-P230 Tray Motor: step 12, image 3 of 3
    • Use your fingers to pull the shown tabs towards the sides of the tray, releasing the internal tray that contains the laser.
  13. Replacing Samsung DVD-P230 Tray Motor: step 13, image 1 of 2 Replacing Samsung DVD-P230 Tray Motor: step 13, image 2 of 2
    • In order to remove the tray motor you must detach the small rubber band that runs between the two shown wheels.
    • If the rubber band is improperly fitted onto one of the wheels or broken this is probably the cause of the tray not opening or closing.
  14. Replacing Samsung DVD-P230 Tray Motor: step 14, image 1 of 2 Replacing Samsung DVD-P230 Tray Motor: step 14, image 2 of 2
    • Flip over the tray and unscrew the two screws that attach the motor to the tray.
    • Once completed the motor can be easily removed and replaced.
Mitchell Hart
903 Reputation
5 Guides authored
Cal Poly, Team 3-30, Regan Winter 2011 Member of Cal Poly, Team 3-30, Regan Winter 2011
CPSU-REGAN-W11S3G30
4 Members
8 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 16
All Time: 5,039
