Introduction
This guide will show how to remove the camera's lens.
Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
Remove the back case of the camera carefully.
The covers are attached with very small tabs around the cover perimeter. A very small blade screwdriver is helpful in prizing the covers apart and off.
Remove the blue button control from its position next to the LCD screen.
Pull the ribbon cable to disconnect the blue button control from the camera.
Remove the back LCD screen from its place carefully.
samsung es90 lcd Where to call the address
I live in Bangladesh
The white LCD is attached to the housing with sticky tape. Again a small blade screwdriver is helpful to CAREFULLY pry it out.
Where can i find a replacement lcd screen?
Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
Remove the circuit board cover
5 other people completed this guide.
Only one screw on bottom of camera
John Petralito - Reply
