Samsung DV180F Repair Display Screen Replacement
    1. Samsung DV180F Repair Display Screen Replacement, Display Screen: step 1, image 1 of 3 Samsung DV180F Repair Display Screen Replacement, Display Screen: step 1, image 2 of 3 Samsung DV180F Repair Display Screen Replacement, Display Screen: step 1, image 3 of 3
      • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
      • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
      • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
      Ask FixBot
    2. Samsung DV180F Repair Display Screen Replacement: step 2, image 1 of 2 Samsung DV180F Repair Display Screen Replacement: step 2, image 2 of 2
      • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
      • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
      • Use the prying tool to unhook the casing from the plate covering the motherboard
      Ask FixBot
    3. Samsung DV180F Repair Display Screen Replacement: step 3, image 1 of 3 Samsung DV180F Repair Display Screen Replacement: step 3, image 2 of 3 Samsung DV180F Repair Display Screen Replacement: step 3, image 3 of 3
      • Release the ribbon from the button casing connected to the motherboard.
      • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
      • Replace the screen then repeat all of these steps in reverse order to reassemble.
      Ask FixBot
4 other people completed this guide.
Evan McGettrick
232 Reputation
1 Guide authored
USF Tampa, Team 14-4, Eyestone Fall 2016 Member of USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Members
48 Guides authored
2 Guide Comments
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - Reply Share
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 115
All Time: 1,334
