Samsung Brightside Speaker Module Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
92
All Time:
1,556
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
I noticed that there was not to much information about working on this phone. I received one in a non-working condition and figured it would be a good chance for some guides. The phone is easy to work on and no hidden screws or clips, no excessive glue. A straight forward no nonsense phone.
Tools
    1. Samsung Brightside Speaker Module Replacement, Speaker Module: step 1, image 1 of 3 Samsung Brightside Speaker Module Replacement, Speaker Module: step 1, image 2 of 3 Samsung Brightside Speaker Module Replacement, Speaker Module: step 1, image 3 of 3
      • Here is the Samsung SCH-U380 Brightside
      • Turn it over to gain access to the battery.
      • Remove the backcover by simply pulling it off the phone from the top down
      Ask FixBot
    2. Samsung Brightside Speaker Module Replacement: step 2, image 1 of 3 Samsung Brightside Speaker Module Replacement: step 2, image 2 of 3 Samsung Brightside Speaker Module Replacement: step 2, image 3 of 3
      • Remove the battery
      • Remove the six Phillips screws from the back frame
      • All six screws are identical M1.5X3
      Ask FixBot
    3. Samsung Brightside Speaker Module Replacement: step 3, image 1 of 3 Samsung Brightside Speaker Module Replacement: step 3, image 2 of 3 Samsung Brightside Speaker Module Replacement: step 3, image 3 of 3
      • Use a plastic opening tool or similar tool to separate the top from the bottom frame. Applying slight pressure in a downwards direction will disengage the plastic clips
      • Continue to slide the tool along the slot until you feel the plastic locks disengage
      • Once all locks have released, the bottom frame can simply be removed.
      Ask FixBot
    4. Samsung Brightside Speaker Module Replacement: step 4, image 1 of 3 Samsung Brightside Speaker Module Replacement: step 4, image 2 of 3 Samsung Brightside Speaker Module Replacement: step 4, image 3 of 3
      • Remove the two Phillips screws from the EMI shield.
      • Both screws are identical M1.5X2
      • Remove the EMI shield
      Ask FixBot
    5. Samsung Brightside Speaker Module Replacement: step 5, image 1 of 3 Samsung Brightside Speaker Module Replacement: step 5, image 2 of 3 Samsung Brightside Speaker Module Replacement: step 5, image 3 of 3
      • Detach the LCD connector.
      • Remove the logic board
      • This is the speaker module. In the center is the camera, but it is not part of the module.
      Ask FixBot
    6. Samsung Brightside Speaker Module Replacement: step 6, image 1 of 3 Samsung Brightside Speaker Module Replacement: step 6, image 2 of 3 Samsung Brightside Speaker Module Replacement: step 6, image 3 of 3
      • turn the logic board over. The speaker module is held in place
      • by one Phillips screw
      • and two clips
      • Remove the Phillips screw.
      • It is a M1X2 Phillips screw
      • Next disengage one of the clips by simply applying some sideways pressure with your fingernail. This will loosen the module.
      Ask FixBot
    7. Samsung Brightside Speaker Module Replacement: step 7, image 1 of 2 Samsung Brightside Speaker Module Replacement: step 7, image 2 of 2
      • Turn the logic board around. With the speaker module loose, simply lift it off the board.
      • Speaker module removed.
      • Camera
      • and audio jack
      • are not part of this module and will remain on the board.
      Ask FixBot
oldturkey03
862,966 Reputation
123 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 92
All Time: 1,556
