Samsung BD-D5500 Disc Drive Replacement
  1. Samsung BD-D5500 Disc Drive Replacement, Samsung BD-D5500 Disassembly: step 1, image 1 of 1
    • To begin, turn the device over so that the bottom is facing up. There are 9 black clips that attach the plastic body to the case. Remove these clips from the case.
  2. Samsung BD-D5500 Disc Drive Replacement: step 2, image 1 of 2 Samsung BD-D5500 Disc Drive Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the screw that attaches the top cover to the rear of the device. This will allow you to remove the cover.
    • This is how your device will look after you remove the top.
  3. Samsung BD-D5500 Disc Drive Replacement, Disc Drive: step 3, image 1 of 1
    • Please locate your disc drive
    • Your disc drive should look like the one pictured. If your disc drive does not look as follows please confirm that you are looking at the right guide.
  4. Samsung BD-D5500 Disc Drive Replacement: step 4, image 1 of 1
    • Once you have located your disc drive it is time to remove the drive
    • You will see four silver 1.1mm Phillips #2 screws located on each corner of the disc drive.
  5. Samsung BD-D5500 Disc Drive Replacement: step 5, image 1 of 2 Samsung BD-D5500 Disc Drive Replacement: step 5, image 2 of 2
    • Once you have removed the four screws using a Phillips #2 screwdriver you are now able to take out the disc drive
    • Carefully remove the disc drive being sure not to disrupt anything else in the Blu-Ray player.
    • This is how your disc drive should look if you have removed it from the player correctly.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 748
