Introduction
This guide will show you how to remove and replace the track pad in your laptop.
Remove the ten 5 mm screws that hold the backplate using the Phillips #000 screwdriver.
Remove the six 5mm screws that hold the battery by using the Phillips #0 screwdriver.
Peel the tape on the track pad back.
Unscrew the five 2mm screws with the J00 Philips head screwdriver.
Rotate the track pad out of the case.
