Samsung A3 2016 Model - A310F Display / LCD Replacement
  1. Samsung A3 2016 Model - A310F Display / LCD Replacement, Display / LCD: step 1, image 1 of 1
    • Remove the SIM tray from the phone.
  2. Samsung A3 2016 Model - A310F Display / LCD Replacement, Removing the battery cover: step 2, image 1 of 1
    • Use a heat gun or iOpener to heat the back of the phone.
    • Insert a spudger or thin bladed tool between the batery cover and frame.
    • Slide all the way around to release the adhesive holding the cover.
    • The battery cover is also glass and can break if too much pressure is applied when removeing.
  3. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 3, image 1 of 2 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 3, image 2 of 2
    • Remove all 16 screws from the housing
  4. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 4, image 1 of 1
    • Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
    • You may need to go around the edge of the glass with a pick to remove any remaining adhesive
  5. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 5, image 1 of 1
    • Remove the Philips screw securing the mainboard.
    • Remove the cable attached to the mainboard
    • Disconnect the display and camera connectors from the mainboard
  6. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 6, image 1 of 2 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 6, image 2 of 2
    • Disconnect the daughter board from the mainboard
  7. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 7, image 1 of 1
    • Using a heatgun, heat the front of the display.
    • Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
    • When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
  8. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 8, image 1 of 3 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 8, image 2 of 3 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 8, image 3 of 3
    • Reattach the daughter board connector to the mainboard.
    • When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
    • Re-connect the display connector, camera and cable to the mainboard.
    • Screw the mainboard to the frame
  9. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 9, image 1 of 1
    • Turn the phone on and test the display before removing the adhesive on the back of the display.
    • If everything works, remove the adhesive and attach the display to the plastic frame.
    • Push the display into the metal housing so it fits snugly.
  10. Samsung A3 2016 Model - A310F Display / LCD Replacement: step 10, image 1 of 2 Samsung A3 2016 Model - A310F Display / LCD Replacement: step 10, image 2 of 2
    • Replace the 16 screws that were removed in step 3.
    • Replace the battery cover and you are done.
5 other people completed this guide.
Harvey
6,189 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 36
All Time: 3,946
