Saitek X52 Pro Disassembly
  1. Saitek X52 Pro Disassembly, Get your tools: step 1, image 1 of 1
  2. Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: step 2, image 1 of 3 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: step 2, image 2 of 3 Saitek X52 Pro Disassembly, Open the Joystick - Unscrewing: step 2, image 3 of 3
    • Please take a moment and note how your joystick is assembled and all the parts that can be dettached. I recommend taking a few photos before dismantling it.
    • With the Phillips screwdrive unscrew the #1 to #4 screws in Fig. 1.
    • Using the Torx T10 head, unscrew the #5 (Fig. 1), #6, #7 and #8 screws (Fig. 2)
    • Screws 5 & 6 have a larger thread pace than 7 & 8, although the heads are the same. So please take care when you screw them back on (Fig. 3).
    • Using your hand, unscrew #9 (Fig. 2). Please note that you cannot completely remove this screw, but you don't need to do this anyway.
  3. Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: step 3, image 1 of 2 Saitek X52 Pro Disassembly, Open the Joystick - Removing the bracket and the cover: step 3, image 2 of 2
    • Carefully remove the plastic bracket and the support holding the "Pinkie trigger" by pushing it towards the trigger (Fig. 4).
    • DO NOT force its removal, or you can break it.
    • Be careful not to break the Pinkie trigger wire!
    • Remove the stick cover that will expose the contacts and wiring (Fig. 5)
  4. Saitek X52 Pro Disassembly, Fixing it: step 4, image 1 of 1
    • Note the small metal plate.
    • Bend it just a little from the middle so that pushing the trigger actually pushes the small blue switch inside the stick.
    • Test the trigger before putting back the plastic cover
    • Remember when screwing the screws that 5&6 go to the bottom sides and 7&8 go at the top.
Cri Cri
611 Reputation
1 Guide authored
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 169
All Time: 26,625
