Shop the Holiday Gift Guide
Saitek ST90 PS22 Disassembly Guide
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
80
All Time:
243
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
I create this guide, so that it can be useful to other owners who want to open it for repairs and other projects.
Feel free to replicate and improve this guide elsewhere on the internet.
    1. Saitek ST90 PS22 Disassembly Guide, Remove screws from the handle.: step 1, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, Remove screws from the handle.: step 1, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, Remove screws from the handle.: step 1, image 3 of 3
      • Remove screws from the handle.
      • two above near the buttons and trigger
      • two below above the spring
      Ask FixBot
    2. Saitek ST90 PS22 Disassembly Guide, Remove blue display.: step 2, image 1 of 2 Saitek ST90 PS22 Disassembly Guide, Remove blue display.: step 2, image 2 of 2
      • Using a screwdriver or equivalent tool, remove the blue display.
      • Its clips are on the side of the blue display.
      • Press the sides inward.
      Ask FixBot
    3. Saitek ST90 PS22 Disassembly Guide, Remove "+" and "-" buttons.: step 3, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, Remove "+" and "-" buttons.: step 3, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, Remove "+" and "-" buttons.: step 3, image 3 of 3
      • Your staples are above and below in center.
      • it's easier to press the bottom ones first.
      Ask FixBot
    4. Saitek ST90 PS22 Disassembly Guide, Hidden plastic clips of the top buttons.: step 4, image 1 of 2 Saitek ST90 PS22 Disassembly Guide, Hidden plastic clips of the top buttons.: step 4, image 2 of 2
      • Locate the plastic hidden clips of the top buttons.
      • obs: I started by releasing the large buttons by their side latches, then I discovered that releasing the hidden latches in a UU-shape also allows you to release the button.
      Ask FixBot
    5. Saitek ST90 PS22 Disassembly Guide, Remove the large buttons.: step 5, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, Remove the large buttons.: step 5, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, Remove the large buttons.: step 5, image 3 of 3
      • With a thin screwdriver, press the latches.
      • They are shaped like 2 UU upside down, where they are attached to a plastic cylinder.
      Ask FixBot
    6. Saitek ST90 PS22 Disassembly Guide, Separate the two halves of the handle.: step 6, image 1 of 2 Saitek ST90 PS22 Disassembly Guide, Separate the two halves of the handle.: step 6, image 2 of 2
      • Always be careful, because of the wiring.
      Ask FixBot
    7. Saitek ST90 PS22 Disassembly Guide, Access trigger, spring and internal wiring.: step 7, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, Access trigger, spring and internal wiring.: step 7, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, Access trigger, spring and internal wiring.: step 7, image 3 of 3
      Ask FixBot
    8. Saitek ST90 PS22 Disassembly Guide, Top cover: step 8, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, Top cover: step 8, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, Top cover: step 8, image 3 of 3
      • OBS: I managed to remove the top cover with two plastic spatulas, one on each side. But then I discovered that removing it would be unnecessary. Just split the casing and it will be possible to release the top cover.
      Ask FixBot
    9. Saitek ST90 PS22 Disassembly Guide, Dismantling of the base: step 9, image 1 of 2 Saitek ST90 PS22 Disassembly Guide, Dismantling of the base: step 9, image 2 of 2
      • 1 - Remove the plastic adhesive using a spatula or a utility knife.
      • Remove the 4 screws from the base using a small Phillips screwdriver.
      Ask FixBot
    10. Saitek ST90 PS22 Disassembly Guide, Detach the cover base and the orange disc.: step 10, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, Detach the cover base and the orange disc.: step 10, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, Detach the cover base and the orange disc.: step 10, image 3 of 3
      • After removing the base cover, you will see the metal parts; remove them by prying them outwards with a tool.
      • These parts are responsible for keeping the base stable.
      Ask FixBot
    11. Saitek ST90 PS22 Disassembly Guide, Remove the feet from the base.: step 11, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, Remove the feet from the base.: step 11, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, Remove the feet from the base.: step 11, image 3 of 3
      • 1- Locate the footrest and the base.
      • 2-Unscrew it using a small TORX key.
      • obs: Pay attention to the nut on the opposite side of the bolt.
      Ask FixBot
    12. Saitek ST90 PS22 Disassembly Guide, Note: concealed plastic cylinder.: step 12, image 1 of 2 Saitek ST90 PS22 Disassembly Guide, Note: concealed plastic cylinder.: step 12, image 2 of 2
      • After removing the screws securing the three legs, the plastic cylinders located in the base's mounting holes might remain in place and fall out on their own.
      • Finally, if you prefer not to keep the feet and the orange disc, install the metal parts and screw the base cover into place.
      Ask FixBot
    13. Saitek ST90 PS22 Disassembly Guide, General images: step 13, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, General images: step 13, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, General images: step 13, image 3 of 3
      Ask FixBot
    14. Saitek ST90 PS22 Disassembly Guide, General images 2: step 14, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, General images 2: step 14, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, General images 2: step 14, image 3 of 3
      Ask FixBot
    15. Saitek ST90 PS22 Disassembly Guide, General images 3: step 15, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, General images 3: step 15, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, General images 3: step 15, image 3 of 3
      Ask FixBot
    16. Saitek ST90 PS22 Disassembly Guide, General images 4: step 16, image 1 of 3 Saitek ST90 PS22 Disassembly Guide, General images 4: step 16, image 2 of 3 Saitek ST90 PS22 Disassembly Guide, General images 4: step 16, image 3 of 3
      Ask FixBot
Author
with
Darkstone
289 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 80
All Time: 243
