Up to 20% off select tools
Safety Precautions
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
3
All Time:
121
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Very easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Safety Precautions
Introduction
Go to step 1 ↓
Safety precautions to follow before conducting repairs on an EDCO KL-18 Concrete Saw model 39600-HD.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
    1. Safety Precautions, Chock the wheels: step 1, image 1 of 2 Safety Precautions, Chock the wheels: step 1, image 2 of 2
      • Before you begin, ensure the machine is powered down and cool to the touch.
      • Chock the wheels to prevent the machine from moving while you are working on it.
      Ask FixBot
    2. Safety Precautions, Turn off the ignition switches: step 2, image 1 of 3 Safety Precautions, Turn off the ignition switches: step 2, image 2 of 3 Safety Precautions, Turn off the ignition switches: step 2, image 3 of 3
      • Flip the ignition switches on the motor and the handle bar into their "OFF" positions.
      Ask FixBot
    3. Safety Precautions, Close the fuel valve: step 3, image 1 of 2 Safety Precautions, Close the fuel valve: step 3, image 2 of 2
      • Flip the fuel cutoff valve switch into the off position.
      Ask FixBot
    4. Safety Precautions, Disconnect the spark plug: step 4, image 1 of 2 Safety Precautions, Disconnect the spark plug: step 4, image 2 of 2
      • Grab the plastic housing at the end of the spark plug wire.
      • Pull firmly to disconnect the wire from the spark plug.
      Ask FixBot
Sam Omiotek
101,798 Reputation
289 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 121
