This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Why! NH57ADS M.2 SSD Replacement
  1. Why! NH57ADS M.2 SSD Replacement, Battery: step 1, image 1 of 3 Why! NH57ADS M.2 SSD Replacement, Battery: step 1, image 2 of 3 Why! NH57ADS M.2 SSD Replacement, Battery: step 1, image 3 of 3
    • Remove the two screws holding the battery in place.
    • Slip your finger into the finger hole provided at the top of the battery and lift to remove it.
  2. Why! NH57ADS M.2 SSD Replacement, Bottom Cover: step 2, image 1 of 3 Why! NH57ADS M.2 SSD Replacement, Bottom Cover: step 2, image 2 of 3 Why! NH57ADS M.2 SSD Replacement, Bottom Cover: step 2, image 3 of 3
    • Remove the five Phillips screws securing the bottom to the case.
    • Slide the cover up slightly to release the catches holding it in place. This is the view on the right. The mark on the cover should now line up with the second mark on the case of the computer.
  3. Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: step 3, image 1 of 3 Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: step 3, image 2 of 3 Why! NH57ADS M.2 SSD Replacement, Removing the Bottom Cover: step 3, image 3 of 3
    • This is the view on the left before and after sliding the cover. The mark on the cover should now line up with the second mark on the case of the computer.
    • Lift the bottom cover to remove it.
  4. Why! NH57ADS M.2 SSD Replacement, Remove the M.2 SSD: step 4, image 1 of 2 Why! NH57ADS M.2 SSD Replacement, Remove the M.2 SSD: step 4, image 2 of 2
    • Remove the Phillips screw securing the M.2 SSD drive in place. The end of the drive will pop up by a small amount.
    • Slide the drive out from the connector in a straight line. If you feel resistance, try raising it slightly.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
80%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 5
All Time: 331
