SPOT X SPOTXB Antenna Replacement
  1. SPOT X SPOTXB Antenna Replacement, Antenna: step 1, image 1 of 3 SPOT X SPOTXB Antenna Replacement, Antenna: step 1, image 2 of 3 SPOT X SPOTXB Antenna Replacement, Antenna: step 1, image 3 of 3
    • Turn off the device completely by holding the power button for 10-20 seconds to force a shutdown.
  2. SPOT X SPOTXB Antenna Replacement: step 2, image 1 of 1
    • Remove the seven 4.1 mm screws from the back of the device using a T4 Torx screwdriver.
  3. SPOT X SPOTXB Antenna Replacement: step 3, image 1 of 1
    • Gently separate the back cover from the rest of the device.
  4. SPOT X SPOTXB Antenna Replacement: step 4, image 1 of 1
    • Gently unplug the antenna connector from the device's internal board.
    • Remove the antenna from the device.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 201
