This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
SNK Neo-Geo X Battery Replacement
    1. SNK Neo-Geo X Battery Replacement, Unscrew the rear case: step 1, image 1 of 2 SNK Neo-Geo X Battery Replacement, Unscrew the rear case: step 1, image 2 of 2
      • Remove the memory card.
      Ask FixBot
    2. SNK Neo-Geo X Battery Replacement, Remove the 8 screws: step 2, image 1 of 3 SNK Neo-Geo X Battery Replacement, Remove the 8 screws: step 2, image 2 of 3 SNK Neo-Geo X Battery Replacement, Remove the 8 screws: step 2, image 3 of 3
      • Remove the 8 screws: 3 on each long side and 1 on each short side.
      Ask FixBot
    3. SNK Neo-Geo X Battery Replacement, Remove the rear case: step 3, image 1 of 2 SNK Neo-Geo X Battery Replacement, Remove the rear case: step 3, image 2 of 2
      • Gently slide an opening pick along the edge, then carefully lift the rear case.
      • Optional: if the rear case is sticky due to plastic degradation, clean it with WD-40.
      Ask FixBot
    4. SNK Neo-Geo X Battery Replacement, Desoldering the red and black wires: step 4, image 1 of 3 SNK Neo-Geo X Battery Replacement, Desoldering the red and black wires: step 4, image 2 of 3 SNK Neo-Geo X Battery Replacement, Desoldering the red and black wires: step 4, image 3 of 3
      • Peel up the battery.
      • Desolder the two wires.
      • Battery model: AHB355585 (voltage: 3.7 V; technology: Li-polymer; color: black; capacity: 2800 mAh; net weight: 47 g; weight: 97 g; power: 10.36 Wh).
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Gloubi
137 Reputation
1 Guide authored
1 Guide Comment
Une batterie HS peut empêcher la console de démarrer.
Gloubi - Reply Share
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 82
All Time: 628
