Remove IBM WorkPad c3 Battery
Views: 5.1K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
108
All Time:
5,122
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your battery is not working you can remove it and replace it following the step by step process. The battery can easily just pop out following simple steps
Tools
    1. Remove IBM WorkPad c3 Battery, Back Case: step 1, image 1 of 2 Remove IBM WorkPad c3 Battery, Back Case: step 1, image 2 of 2
      • Turn the device over so that the screen is facing down.
      • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
      Ask FixBot
    2. Remove IBM WorkPad c3 Battery: step 2, image 1 of 1
      • Using a hair dryer, slowly heat the edges of the WorkPad.
      • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
      • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
      Ask FixBot
    3. Remove IBM WorkPad c3 Battery: step 3, image 1 of 2 Remove IBM WorkPad c3 Battery: step 3, image 2 of 2
      • Use a plastic opening tool to pry the back case from the WorkPad.
      • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
      Ask FixBot
    1. Remove IBM WorkPad c3 Battery, Battery: step 4, image 1 of 1
      • Remove the yellow tape that is covering the battery connector
      Ask FixBot
    2. Remove IBM WorkPad c3 Battery: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers, carefully disconnect the battery cable from the port
      Ask FixBot
    3. Remove IBM WorkPad c3 Battery: step 6, image 1 of 2 Remove IBM WorkPad c3 Battery: step 6, image 2 of 2
      • Using the plastic opening tools, lift the battery out of the case
      • The battery is secured with adhesive and it will take some effort to remove
      Ask FixBot
Emily Falkenstein
75 Reputation
5 Guides authored
Cal Poly, Team 21-35, Regan Fall 2010 Member of Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 108
All Time: 5,122
