HP Pavilion dv5000 RTC Battery Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
104
All Time:
13,128
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The battery of the HP Pavilion is made to last for only a period of time, after which the battery tends to run low sooner than usual. This means the battery capacity has lessened and may need a replacement. This guide will walk you through the process of accessing the RTC Battery of an HP Pavilion dv5000 in order to replace it.
Tools
    1. HP Pavilion dv5000 RTC Battery Replacement, Battery: step 1, image 1 of 1
      • Turn off the computer, and unplug it from all external power sources.
      • Lay the computer face-down on a flat surface. Orient the computer to match the image.
      • Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
      Ask FixBot
    1. HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: step 2, image 1 of 3 HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: step 2, image 2 of 3 HP Pavilion dv5000 RTC Battery Replacement, RAM Cover: step 2, image 3 of 3
      • Remove the two 5mm Phillips screws on the right side of the RAM cover.
      • Lift the right side of the RAM cover, and remove it.
      Ask FixBot
    1. HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: step 3, image 1 of 2 HP Pavilion dv5000 RTC Battery Replacement, Wifi Card: step 3, image 2 of 2
      • Disconnect the antenna leads from the wifi card by lifting the gold ends of the wires off the prongs on the wifi card.
      • The white wire connects to the AUX terminal.
      • The black wire connects to the MAIN terminal.
      Ask FixBot
    2. HP Pavilion dv5000 RTC Battery Replacement: step 4, image 1 of 2 HP Pavilion dv5000 RTC Battery Replacement: step 4, image 2 of 2
      • Remove the two 6.0mm Phillips screws from the wifi card.
      • Remove the wifi card.
      Ask FixBot
    1. HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: step 5, image 1 of 3 HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: step 5, image 2 of 3 HP Pavilion dv5000 RTC Battery Replacement, RTC Battery: step 5, image 3 of 3
      • Remove the RTC Battery from the battery holder.
      Ask FixBot
4 other people completed this guide.
Farid Khoshnevissan
820 Reputation
4 Guides authored
Cal Poly, Team 21-34, Regan Fall 2010 Member of Cal Poly, Team 21-34, Regan Fall 2010
CPSU-REGAN-F10S21G34
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 104
All Time: 13,128
