SKARSTA Desk O-ring Replacement
    1. SKARSTA Desk O-ring Replacement, O-ring: step 1, image 1 of 3 SKARSTA Desk O-ring Replacement, O-ring: step 1, image 2 of 3 SKARSTA Desk O-ring Replacement, O-ring: step 1, image 3 of 3
      • Remove the height adjustment crank by pulling it down and out from its clip.
      • Do not turn the crank at any point during the process to avoid an alignment issue.
      Ask FixBot
    2. SKARSTA Desk O-ring Replacement: step 2, image 1 of 3 SKARSTA Desk O-ring Replacement: step 2, image 2 of 3 SKARSTA Desk O-ring Replacement: step 2, image 3 of 3
      • Position yourself so you can comfortably reach underneath the desk. This might involve kneeling or sitting next to/under the desk.
      • Remove the two 15.2 mm Phillips #2 screws connecting the crank to the table.
      • Remove the eight 15.2 mm Phillips #2 screws connecting the table to the legs.
      • Do not use a power tool to screw/unscrew the screws, as it may crack the desk.
      Ask FixBot
    3. SKARSTA Desk O-ring Replacement: step 3, image 1 of 3 SKARSTA Desk O-ring Replacement: step 3, image 2 of 3 SKARSTA Desk O-ring Replacement: step 3, image 3 of 3
      • Carefully lift the table off the stand and set it aside.
      • Ask for help if needed to avoid accidentally damaging the desk or if it is too heavy for you.
      Ask FixBot
    4. SKARSTA Desk O-ring Replacement: step 4, image 1 of 3 SKARSTA Desk O-ring Replacement: step 4, image 2 of 3 SKARSTA Desk O-ring Replacement: step 4, image 3 of 3
      • Remove the broken O-ring from the adjustment mechanism.
      • The broken O-ring might not be on the rod as shown in the picture but underneath it.
      Ask FixBot
    5. SKARSTA Desk O-ring Replacement: step 5, image 1 of 3 SKARSTA Desk O-ring Replacement: step 5, image 2 of 3 SKARSTA Desk O-ring Replacement: step 5, image 3 of 3
      • Pull the rod out to detach it from the stand.
      • Set the rod down to use at reassembly.
      Ask FixBot
    6. SKARSTA Desk O-ring Replacement: step 6, image 1 of 3 SKARSTA Desk O-ring Replacement: step 6, image 2 of 3 SKARSTA Desk O-ring Replacement: step 6, image 3 of 3
      • Repeat the previous step on the opposite end of the rod.
      Ask FixBot
    7. SKARSTA Desk O-ring Replacement: step 7, image 1 of 3 SKARSTA Desk O-ring Replacement: step 7, image 2 of 3 SKARSTA Desk O-ring Replacement: step 7, image 3 of 3
      • Slide the new O-ring over the thin side of the rod.
      • There may be lubricant on the rod; avoid wiping it off.
      Ask FixBot
    8. SKARSTA Desk O-ring Replacement: step 8, image 1 of 3 SKARSTA Desk O-ring Replacement: step 8, image 2 of 3 SKARSTA Desk O-ring Replacement: step 8, image 3 of 3
      • Push the thick end of the rod back into the stand to reattach it.
      Ask FixBot
    9. SKARSTA Desk O-ring Replacement: step 9, image 1 of 3 SKARSTA Desk O-ring Replacement: step 9, image 2 of 3 SKARSTA Desk O-ring Replacement: step 9, image 3 of 3
      • Hold the thick end of the rod in place while sliding the thin end outwards.
      • Push the thin end back into the stand while holding the thick end in place.
      • The thick end of the rod might slide out during this process so be sure to hold it in place when sliding and attaching the thin end.
      Ask FixBot
    10. SKARSTA Desk O-ring Replacement: step 10, image 1 of 3 SKARSTA Desk O-ring Replacement: step 10, image 2 of 3 SKARSTA Desk O-ring Replacement: step 10, image 3 of 3
      • Slide the O-ring towards the thicker end of the rod.
      • Pull the thick and thin ends apart and push the O-ring as close to the thick end as possible to secure the rod in place.
      Ask FixBot
    11. SKARSTA Desk O-ring Replacement: step 11, image 1 of 3 SKARSTA Desk O-ring Replacement: step 11, image 2 of 3 SKARSTA Desk O-ring Replacement: step 11, image 3 of 3
      • Carefully place the table back on the stand.
      Ask FixBot
    12. SKARSTA Desk O-ring Replacement: step 12, image 1 of 3 SKARSTA Desk O-ring Replacement: step 12, image 2 of 3 SKARSTA Desk O-ring Replacement: step 12, image 3 of 3
      • Use a Phillips #2 screwdriver to replace the eight 15.2 mm screws securing the table to the stand.
      • Turn all the screws halfway first, then tighten them completely.
      • Use a Phillips #2 screwdriver to replace the two 15.2 mm screws that secure the hand crank.
      • Make sure the handle is facing the correct direction before replacing the screws.
      Ask FixBot
    13. SKARSTA Desk O-ring Replacement: step 13, image 1 of 3 SKARSTA Desk O-ring Replacement: step 13, image 2 of 3 SKARSTA Desk O-ring Replacement: step 13, image 3 of 3
      • Rotate the crank inward to the clip until it clicks into place.
      Ask FixBot
Congratulations! The repair is complete.
Nasser Choudhri
217 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 24
Past 30 Days: 96
All Time: 1,067
